Selling a used Diamond Pacific Genie. Includes the following:
Stock Galaxy wheels (2)
Stock Nova wheels (4)
Additional high grit Nova wheels (3)
Additional Arbor for said high grit wheels (1)
Stock adjustable work lamp (1) (note: This appears to be as original, but does not appear to function. No electrical issues visible, so it may be a connection within the light head itself. Status: not working)
Stock water trays (2) with splash guards (4)
Stock water spraying system
Manual
Manufacturers shipping box and shipping material for the unit (1)
This machine was used for around 2 to 3 years as a hobby level tool. The Galaxy/Nova wheels are worn, but functional. The machine is clean overall, however there's excessive dirt on the Galaxy wheel side under where the cover goes.
As noted above, there is something wrong with the adjustable lamp, but there is no damage to be seen on the unit or the cord, so it's likely a loose wire inside the unit.
Used primarily for softer stones (Opal)
The pump on this machine has been oiled as needed and is working.
(full scale images 4032x3024 and video of the machine running available on request)
Asking $1000 plus shipping
