Author Topic: Aussie stone fish  (Read 9784 times)
auscarver
Aussie stone fish
« on: June 24, 2023, 11:44:06 PM »
It’s been 1 1/2 years since I started this fish and it was about time I finished it. Jade takes so long when I only have a few hours to do carving each week. I will push myself a bit harder as I want to enter in a small sculpture exabition late July. I think I need to replace then white opal eyes with another colour gem. It’s Aussie nephrite jade.
Re: Aussie stone fish
« Reply #1 on: July 01, 2023, 06:53:28 AM »
patience is a virtue, it shows in your piece. Very very nice!
« Reply #2 on: July 01, 2023, 01:42:39 PM »
 :WHOAL: :WHOAR:
auscarver
« Reply #3 on: July 05, 2023, 02:38:55 AM »
Thanks for taking the time to reply. I need to make a stand to show it properly. Timber or metal or a combination of both. My dagger I made back in 2014 I made a polished stainless stand.
« Reply #4 on: July 05, 2023, 07:36:21 AM »
   Both pieces are stunning. keep up the great work.
« Reply #5 on: July 05, 2023, 06:37:56 PM »
Timber or metal, the stand could include some wavy patterns... I would even consider glass or laser-cut acrylic. This fish deserves a nice environment!
« Reply #6 on: July 05, 2023, 10:51:31 PM »
I have a question.  Although I am a Product Designer by training and spent years doing it before retiring I have a certain issue of carving stone.  In working with the various materials as a designer it was easy to have a variety of tools that allowed me to get complex curves done without waves or ripples.  I have no problem with almost any lapidary effort I have tried and feel I am very good at those and then comes carving, ah the death of my pride.  I have found that the harder the material seems the tools available to work it diminishes.  What I find is that in working certain tight radii or a long curving surface I have a problem not developing a certain amount of said waves or ripples.  Depending on the length of the piece being worked and having limited movement on some equipment that seems to add to the issue.  A good example is the scales of a knife are mostly easy with changes to the grinding unit like removing wheels for freedom of movement.  But then enter the finger grooves on the belly and having a Titan grinder lol.  I have found the 1" Chinese grinding wheel at Harbor freight works great but at maybe 80 grit leaves a lot of finished work and hell if you hit the knife spine.  So then it is dremel or foredom time.  I find it would be SO nice if I could even find a 1" version of a nova wheel that would greatly diminish these ripples.  Short of that wheel I can but tons of 100 to 600 diamond burrs/points but these are mostly very small and that really is what causes the surface irregularities from my view.  How on earth do you keep such consistent surfaces?  I assume you could make wooden blocks and Silicon Carbide or Diamond paste the surfaces.  Does anyone make an advanced set of nova like wheels in small sizes?  Best I have found and they are limited are the diamond pacific nova points and i think the large cylinder or bullets are about 3/8ths.  I have always been in awe of carvers on this forum and elsewhere for being able to master these surface challenges.
auscarver
« Reply #7 on: July 09, 2023, 02:51:28 AM »
Thanks for the ideas about the stand. Irockhound. Hand carbide sticks are the answer to smooth curves. I custom cut these in many sizes from 120 grit to 1200. I rough carve with my foredom than smooth with carbide sticks to smooth out all those bumps. A hand polish on diamond or carbide is much better than any high speed tool. See carbide sticks in my attached picture.
Page created in 0.048 seconds with 42 queries.
