Author Topic: Full circle jade ring tutorial  (Read 18930 times)
« on: October 06, 2014, 07:47:25 AM »
You asked for it so here it is. The highly scientific method for making rings out of stone.
First I drill a hole in a thick (1/4 to 3/8 inch) slab the size of the ring that I want to make. 11/16" for a size 7 and 13/16" for size 12. I will be making other sizes when I replace the hole saws that I destroyed drilling agate. In the past I drilled the entire slab, cut around the holes with my trim saw then ground the blanks to where they were close to round by hand. I am switching to drilling the ring size hole then taking a much larger hole saw and drilling the outside of the blank.
The slab clamped in the drill press clamp. My biggest worry here is that the slab will crumble when it gets full of holes.
I have switched to the slab clamped to a brick that is in the tub of water. The clamp will still work if it is easier for you.
I turned the column on the base and lag screwed the base to the table so I would have the room under the drill press table for the clamp
This is my super scientific ring dop stick. Until I came up with this little jewel my rings were pretty uneven. I used small drum sanders to make a holder for the rings so they could be worked on my grinder/polisher.
I spin the drum sander against a file to get it the right size. It is a lot of trial and error a little at a time until the ring slides on the rubber tight enough to hold it from spinning. The good thing is that if you go just a little to far you can tighten it up by turning the nut, It is important to brace the file in such a way that it does not bounce. Because if it bounces you will get a holder that is off center and the ring will be wobbling like crazy. This is the toughest part of the super duper ring dop. I just happened to think that it may be easier to chuck up the drum sander in the drill press and file it down there.
I use the same polishing pads that I use on my cab polishing machine but now the ring is spinning and the pad is in my hand. I place the ring right at the top of the water. The spinning ring sucks up the water for some reason so it is not necessary to place it under the water where you can not see it. Moving to the drill press from the polishing machine has freed up one hand and made it a lot easier to smoke my cigars without getting smoke in my eyes and has there for increased production by two.
Once the ring is polished I file the sharp inside edge of the ring with a fine diamond file.
These are jade from Mel and the photos do not do them justice. They turned out ten times better than I expected and I would put them up against just about any jade ring that I saw in China. Well, except for the dust. lol  With and without flash. The color is somewhere in the middle of the two.
This is dendritic jade also from Mel. It has been a bugger to polish and it still needs some work. I may have to polish it by hand. He said that it is rare so I made one for me and a couple for my son and daughter. There was also enough left over from the slab to make two cabs and they will be kept in the family also.
Re: Full circle jade ring tutorial
« Reply #1 on: October 06, 2014, 04:30:13 PM »
Hrm...
OK I'm going to attempt some editing of the code here to make your pictures work.
OK edited them.  Links work now.  You used the board code for images instead of the URL code.  I know you would think that images would use image code right?  Not really.  If you are linking from an external site, URL code works better.  Don't know how to get them to appear as images in the post but at least the links are cleaned up.
« Reply #2 on: October 06, 2014, 04:36:42 PM »
That's some great work you've done Jim; I bow down, and you've had some killer material to work with :headbang:
« Reply #3 on: October 06, 2014, 05:44:04 PM »
Thanks Larry uh  :dontknow: Oh yea, Llloyyd
There is a problem with the pics showing up and I had to stop in the middle of trying TRYING to fix it when I had to take my son to the Doctor. When I got back my time had expired so I could not do anything with it. Can I say "I tried to tell ya'll"? Anyway help is on the way sometime later which will be after my bed time because I have been up since 4 am with no naps. So damn nice out I had to leave it me out.
« Reply #4 on: October 06, 2014, 06:08:27 PM »
you all did it wrong.
post a link to the image then (without the stars) [img*]address here[/img*]
« Reply #5 on: October 06, 2014, 06:39:02 PM »
I did a copy and paste from RTH and what you saw is what it pasted. :dontknow:
Thanks for the fix.
« Reply #6 on: October 07, 2014, 05:07:36 AM »
Only half of the photos are there. I need to be able to edit this post.
Page created in 0.071 seconds with 40 queries.
