Author Topic: Anyone here ever convert a 7" tile saw to use 8" lapidary blades  (Read 4411 times)
sealdaddy
« on: December 21, 2015, 12:59:29 AM »
I was recently given a tile saw, but want more cutting height with it than the 1 3/8" you get with a 7" blade.
Has anyone here ever converted a 7" tile saw to use 8" lapidary blades?
thanks
Re: Anyone here ever convert a 7" tile saw to use 8" lapidary blades
« Reply #1 on: December 21, 2015, 03:48:56 AM »
depending on the saw type slide or drop.
it shouldnt be a big deal, if its a slide saw just be careful the larger blade doesnt hit the pan.
« Reply #2 on: December 21, 2015, 05:34:52 AM »
There will be more torque on the motor also so it may stress it if you get too much force into the blade. I assume you have to extend the slot in the table  and of course remember Randy's advice.
sealdaddy
« Reply #3 on: December 22, 2015, 03:50:09 AM »
It has the blade coming Up thru the table.  Not on rails above the table.
« Reply #4 on: December 22, 2015, 06:55:21 PM »
so just mount it, if it clears the bottom of the pan you are golden.
If not, put some feet on the base and take a hammer to the bottom and round it out under the blade to make clearance = farm fix lol!
Page created in 0.028 seconds with 29 queries.
