Author Topic: Genie trim saw attachment  (Read 4127 times)
Back
« on: August 08, 2016, 01:35:24 PM »
Hi All
Has anyone found another blade that will fit this other than the DP blade that was made for cutting glass? I am thinking about modifying it so I can fit a 5/8 inch arbor saw blade on it.
Any feedback would be helpful.
Bless
Shawn
Re: Genie trim saw attachment
« Reply #1 on: August 08, 2016, 08:02:14 PM »
Only other blades I've found are very expensive from a specialty diamond tool maker. The only good thing about them is that the core is made of high tech memory steel. Last time I checked, they had a min. order of 10 blades.
Check some of the Chinese blades. They may make a knockoff to fit the Genie.
« Reply #2 on: August 08, 2016, 11:02:54 PM »
Genie has a 1" arbor, the Australian guys at Quartzsite in the Desert Gardens show as I bought some Chinese blades 6" and up with 1" with shims to downsize if needed so they are out there.
Back
« Reply #3 on: August 09, 2016, 01:53:18 PM »
Hi All
Thanks for the replies.
Jake thanks for getting me thinking about off brands. I found on ebay  a notched 1 inch bore for 20$ and a 25mm continous rim for 30$ I an sure that I will have no problem opening that hole up by .4 of a mm. I will let you all know how that works.
Bless
Shawn
« Reply #4 on: August 09, 2016, 04:37:36 PM »
Just a note for Quartzsite, the Australian guys charge 6 to 10 dollars for the 6" blades if you have a chance to go next January and if you buy a bunch they lower the price.
Back
« Reply #5 on: August 14, 2016, 08:28:44 AM »
Hi All
It would be a dream come true to go to a big show. I did order a blade from China so I am waiting. I did ping or dimple the blade that I do have as I read about here. It did work for about 15 min. before it was dull again but I was able to cut 2 small preforms.
I do like my Genie but the more I think about it the more ticked off I get about the attachment. It is not cheep and all DP offers is a glass blade and the arbor size is non standard. What were they thinking :Bash: :Bash:
End of mini rant but I just am playing the waiting that might last until September.
Bless
Shawn
« Reply #6 on: August 14, 2016, 11:37:54 AM »
DP was thinking that they'd make a trim saw attachment with an odd arbor size so we'd have to buy blades from them. Didn't take China long to catch on to DP's scam.  :LOLOL:
Back
« Reply #7 on: August 19, 2016, 01:25:49 PM »
Hi All
I just got my new saw blade from China and I cant wait to try it :headbang: Within 5min I bored it to fit. In the pic you will see the DP blade on the left and the new blade on the right. I will save the DP blade if I ever have to cut something soft or very expensive. The new blade looks like a work horse :thumbsup: So I now have a new question. What is your favorite additive for a water cooled blade that will help extend the life of my blades?
Bless
Shawn
« Reply #8 on: August 20, 2016, 07:06:32 AM »
I add a few tablespoons of borax as a wetting agent and a few tablespoons of sodium nitrite (food preservative) as a rust preventative.
Page created in 0.078 seconds with 42 queries.
