Author Topic: Clear thread for Bead Embroidery  (Read 11105 times)
TD
« on: August 27, 2016, 12:30:04 AM »
Hello,
I'm new to this site so please bear with me.
I've just started a Embroidery picture which uses seed beads all the way through. I'm wanting to use a clear thread instead of the white because it doesn't interfere with the colour of the beads. Would anyone on here know which clear thread would be best for this?
Thanks
TD
Re: Clear thread for Bead Embroidery
« Reply #1 on: August 27, 2016, 11:33:07 AM »
Would the right fishing line work?  It would be cheap and come in various "gauges" called test lb. for fishing line.  The smaller the test lb. the thinner the line.
« Reply #2 on: August 27, 2016, 06:39:24 PM »
I wonder if something like this would work for you:  http://www.artbeads.com/ill10cl50.html
TD
« Reply #3 on: August 27, 2016, 08:54:48 PM »
 :icon_thumright: Thank you for the replies, I will have a look at this option I think it may be the perfect solution.
« Reply #4 on: September 14, 2016, 11:23:20 AM »
Sorry I didn't see this post till today!
I do bead embroidery regularly.  If I am using beads that are translucent and don't want the thread to interfere with the color I use the "crystal" Fireline found here:  http://www.firemountaingems.com/shop/fireline-thread
TD
« Reply #5 on: September 17, 2016, 10:20:50 PM »
Thank you Enchantra, I have started using this already and it works perfectly for what I need and so much easier to work with, doesn't get tangled up etc.
Thanks
Page created in 0.052 seconds with 36 queries.
