Pages: 1 [2]  All   Go Down
Author Topic: Strange Rock from Lyme Regis?  (Read 8234 times)
Re: Strange Rock from Lyme Regis?
« Reply #15 on: November 18, 2016, 07:17:25 PM »
Glass is easily scratched with Quartz. You didn't have any success when you tried to scratch! So I vote not glass.
« Reply #16 on: November 18, 2016, 07:21:29 PM »
My kids and i actually walk the beaches for glass
MGoy
« Reply #17 on: November 19, 2016, 02:29:47 AM »
I had a Knee Jerk reaction of disappointment when I thought it could be man made glass. But then after letting that idea settle, I became more doubtful, I as a human being have a ton of experience with man made glass and this...... thing, does not feel like it, I know it is worn beyond any recognition.
My arguments against :
* Its 6mm thick, uncommon for man made glass?
* Its so very very very dark black (I have suspicions it may actually be very very very dark purple in reality), there is 0% light getting through it, again uncommon?
* My density calculation (If correct) of 2.87 puts it outside the range of normal man made glass (2.5 - 2.8 I believe)
* I believe it to be harder than man made glass
* Those marking are 99% certainty man made
* This is me im talking about, the chances of me going to a famous geological site and picking up a man made object for the sake of irony..
* There was works rubble on site, increasing the odds.
I'm sure you and your family make great things from found glass, and you have a great time doing so, I'm sorry about my knee jerk judgement about man made glass.
There's something about this thing, when i hold it I'm so so certain its not just a bit of glass or a bit of bathroom tile etc, I could of course be wrong. It would be nice to know for sure.
Thank you :)
« Reply #18 on: November 19, 2016, 05:10:42 AM »
  Calculating density by dimension is virtually impossible.  Try displacement instead.  Fill a container with water and weigh it.  Then put your sample in and remove.  This is easier if you tie a piece of fishing line around it first.  Then weigh again to find the weight of water that has been displaced.  This will give an accurate volume to check against the weight of the sample.  Be sure to wipe the outside dry before weighing.
  Those lines certainly appear to be made by machine but I can't think of any machine that would do that other than a metal planer.  That's not something that would be used on any natural material or even glass.
Talusman
« Reply #19 on: November 19, 2016, 06:51:13 PM »
I believe the lines would have been molded in when the piece was produced. Agree that displacement method is better used to try and determine density. Does it scratch glass?
-Jeremy
Ranger_Dave
« Reply #20 on: November 19, 2016, 07:18:11 PM »
Not all glass is thin, or transparent. That could be some kind of structural glass. I think they used a lot of that in the 1950's. Or it could have served some industrial purpose, an insulator of some kind. The evenness of the thickness, and those grooves, are certainly human made. It could even be a piece of slag glass.
MGoy
« Reply #21 on: November 21, 2016, 09:07:13 AM »
Right I have done what has been suggested :
As follows, I first got a glass of water and used a pippette to get the water level above the rim of the glass.
I then lowered the ... thing, via a thread into the water, being careful to be slow and not touch the bottom of the glass.
After removing the thing . . . and drying up all spillages i weighed the water filled glass again.
Glass Full : 683 grams
Glass After : 670 grams
Difference : 13 grams, weight of water 1gram per 1cm^3
Therefore this thing is 13cm^3
36grams / 13cm^3 = 2.769grams per cubic centimeter.
It looks like it is in fact in the realms of glass, although right on the edge in density.
Pages: 1 [2]  All   Go Up
Page created in 0.025 seconds with 30 queries.
