Author Topic: To paint or not to paint?  (Read 1800 times)
Grayco
« on: January 22, 2017, 02:39:35 PM »
So, I'm looking at this saw and wondering...... Is there any reason to paint the inside of the box?  It's going to be covered in mineral oil. After I removed all the old paint from the inside I kind of like the look of unfinished metal.
Do any of you suffer from corrosion on untreated steel inside a saw?
-Red Green-
Re: To paint or not to paint?
« Reply #1 on: January 22, 2017, 03:45:22 PM »
I don't bother to paint the inside.  As you noted, the oil will prevent an rust.
Barclay
« Reply #2 on: January 22, 2017, 03:49:03 PM »
Paint would help with protection from abrasion.
Grayco
« Reply #3 on: January 23, 2017, 05:17:17 AM »
I hadn't thought about the abrasion issue.  This saw is made of 16 Ga. steel.  I could keep a sheet of plastic on the bottom and replace it as time dictates.
Thanks for the thought.
-Red Green-
Grayco
« Reply #4 on: January 23, 2017, 05:19:46 AM »
Thanks for all your inputs.  I believe I will leave all my saws Paint-less on the inside.  I think it will make maintenance easier and a surface covered in oily rock dust isn't going to look any better with paint on it.
-Red Green-
Page created in 0.046 seconds with 34 queries.
