Pages: 1 [2]  All   Go Down
Author Topic: Unusually hard jasper or chert?  (Read 6752 times)
socalagatehound
Re: Unusually hard jasper or chert?
« Reply #15 on: March 17, 2017, 01:42:34 PM »
Hi Erika
Run your fingernail along the edge of the blade (NOT running) and see if you can feel the roughness from the diamonds. If so, the blade is fine. If not, dress it with a chunk of old silicon dioxide grinding wheel. You can clamp it in the vise and cut it or do it by hand. One pass all the way around should be enough.  If the blade still won't cut any faster, flip it around. Dense agates  (like Brazilian) and porcelain jaspers (Oregon especially) will cause the edge to glaze and hide the diamonds, especially if its a brand that does not have a super high diamond concentration. Also, thicker blades can require more time to cut through hard materials because their grinding away more rock. My only experience is with 18 and 20" slab saws, and a 10 inch slab saw set up as a trim saw. I run smaller rock thru it by hand and use the thinnest blades so I don't stand there all day on one rock.  :grin:
Hope this somehow helps.
Craig
Grayco
« Reply #16 on: March 17, 2017, 02:28:43 PM »
You might try hammering the edge of the blade as shown on page 6 of this document.
http://www.beehiverockandgem.com/files/rocksaws.pdf
-Red Green-
« Reply #17 on: March 17, 2017, 06:06:08 PM »
One more thing others here might (or might not) confirm for us all. I was told to cut a plain ol' brick when I first got into lapidary, but was told later on to use fire brick instead of red brick. It has more abrasive materials in it than regular brick, but a chunk of old grinding wheel is best of all.
« Reply #18 on: March 17, 2017, 06:47:47 PM »
I'm as law-abiding as the majority of the world, and a retired Department of Interior scientist,  . . . but no commercial collecting is more likely to refer to your hauling out dump truck loads and staging major store fronts, than your selling a slab or six of a rock removed from public land.  The day that rocks removed from public lands are not available for trade or sale in reasonable amounts is the day that we all fail to trade or buy material.  We all must make our own decisions on what this means, but I don't think the commercial issue is a big one unless its pushed beyond reasonable.  \
The point about porcelain jaspers and similar stuff glazing blades is probably right on.  The way to prove it is to swap out a different blade to see if difference appear to be blade related.
Kaljaia
« Reply #19 on: March 18, 2017, 10:20:31 PM »
Thanks all for the advice! I don't have any old grinding wheels but will keep that in mind. I do have a fire brick laying around someplace.
Each cut took about fifteen or twenty minutes. I don't know how this compares...?
The blade is still 'rough' to the touch. I'll get a picture of it next time I have the saw out. It is a thick blade, but I have a loose bolt somewhere so it's got more play than I want. I think it's a loose carriage bolt on the drive shaft, tends to cut a wider slot than the blade itself and is also at a very slight angle. Blade makes contact with the stone on one side, has a gap on the other. I've remounted the blade a couple times so it doesn't seem to be a problem with the mounting. I'm going to chalk it up to a hard rock at this time, but I'll set a timer next time and compare it with cutting a t-egg and some other agate, see how it goes.
- Erika
Pages: 1 [2]  All   Go Up
Page created in 0.023 seconds with 26 queries.
