Pages: 1 [2]  All   Go Down
Author Topic: Working The Back Of A Cab  (Read 5226 times)
Re: Working The Back Of A Cab
« Reply #15 on: July 20, 2017, 04:22:49 PM »
Yep, worked!  Beautiful!
womanwithatorch
    • womanwithatorch.com
« Reply #16 on: July 21, 2017, 09:18:59 AM »
This is beautiful, looks like bubbles in the stone.  Please share how you worked the back of the chalcedony to get this look.
bobby1
« Reply #17 on: July 21, 2017, 11:38:35 AM »
I ground the hole with a diamond ball bur. Sanding was done with wood dowel pieces shaped with a file and mounted on a screw tip mandrel. I used tumbling grit to sand the holes. Using another wood shaped dowel I polished the hole.
In an upcoming article in Rock and Gem Magazine under the heading "Bench Tips" I wrote a detailed description on how to do this work. I believe the article will be in the next (August) issue.
Bob
bobby1
« Reply #18 on: July 21, 2017, 11:40:11 AM »
OOPS! It will be in the September issue.
Bob
edgarscale
« Reply #19 on: July 21, 2017, 06:24:30 PM »
the rock and gem magazine still going?    damm i got to get out more :toothy10:
       ='s one great pendant
womanwithatorch
« Reply #20 on: July 31, 2017, 11:29:25 AM »
Thanks for the explanation. I've just bought a subscription to Rock and Gem, hopefully I'll get the September issue.
Pages: 1 [2]  All   Go Up
Page created in 0.032 seconds with 36 queries.
