Congratulations to Sandsave and his Crinoid Cab!
Author Topic: curved metal file?  (Read 700 times)
Neural
  • Opal Addict
curved metal file?
« on: September 22, 2017, 04:09:21 PM »
I'm looking to turn the edge of some .065" sheet metal into something substantially less sharp than it currently is.
I have used flat files in the past, but have run into problems where if it catches, suddenly I'm filing along the file, creating notches in the edge of the sheet.
Does anyone have suggestions on how to smooth/dull the edges of aluminum sheet metal that is around 24" on a side?
I was thinking a curved half round metal file would be perfect, as it would seem to remove the potential notching issue, but I'm not sure a tool like that exists.
Re: curved metal file?
« Reply #1 on: September 22, 2017, 04:29:42 PM »
Ohh, yes, they do exist.
You could also look for sanding-sticks as they are usually of a finer grit.
IMG_20170923_072609 by Kainzer  Kurt, on Flickr
« Reply #2 on: September 22, 2017, 05:02:12 PM »
600 grit sand paper and a sanding block
« Reply #3 on: September 23, 2017, 07:00:19 PM »
I agree with Jhon, I would use a block of wood or steel block and some 600 sandpaper.  If I did need to do it with a file I would use the largest fine file I could get and run the length of the file as parallel to the sheet edge as possible to reduce any gouging.  The more the file is perpendicular to the sheet edge the more you'll run into that problem.
Page created in 0.09 seconds with 30 queries.
