Congratulations to yukonjade and his Richardson Ranch Thunderegg Cab!
Author Topic: Working soft minerals  (Read 487 times)
jerrysg
« on: October 05, 2017, 04:43:05 PM »
A couple of weeks ago we went with one of our clubs to the Four Metals Mine in southern Arizona and worked through the mine dumps.  Came back with a nice piece of rhodochrosite that I would like to work. Dimensions 2 3/4" x 1 1/4" x 3/4" at largest dimensions. Hardness has been given as 3.5.  Any tips, suggestions or hints on working this stone would be greatly appreciated.
Re: Working soft minerals
« Reply #1 on: October 06, 2017, 11:47:52 AM »
I cut a lot of Argentinian rhodo and find it quite easy going with some care.  I don't grind on any hard wheel coarser than 220 grit and I use much less pressure than when grinding hard agate or jasper.  I use a Genie and my sanding sequence on Novas is 280, 600, 1200, 3000 and -- if needed -- 8000.  Sometimes a kiss with Zam on muslin or felt will bring up a brighter polish.  Don't overheat!
jerrysg
« Reply #2 on: October 06, 2017, 05:08:53 PM »
Gemfeller,
Thank you. That's exactly the info I was looking for.
Jerry
« Reply #3 on: October 06, 2017, 07:55:00 PM »
Thats a quite unusual piece.  I have never seen a Lavender or Purple Rhodochrosite before.  Is that color unique to the Four Metals Mine?
jerrysg
« Reply #4 on: October 06, 2017, 08:29:22 PM »
Shot with my phone. Color is off. It is an opaque pink in real life.
Jerry  :embarrassed:
« Reply #5 on: October 07, 2017, 09:27:38 AM »
That sounds much better.  Photos can be quite misleading that way.  The material looked great just didn't match real life Rhodochrosite.  It has great potential, good luck on the cutting.
Page created in 0.07 seconds with 35 queries.
