Congratulations to Stonemon and his White Plume Agate and Sandsave and his Coprolite!
Author Topic: Help with vibralap  (Read 363 times)
duncan
Help with vibralap
« on: October 23, 2017, 03:52:15 PM »
Hi.  I have just started using an old vibralap for the first time on a fairly large jade slab.  Things seems to have gone well through all the grits.  I am now at polish stage.  The "carpet" I have has a rough pebbled side and a smoother side.  The smoother side seems to have polish on it from the previous user.  I have 2 questions:  1) should the rough side be down on the pan and the smoother side be what the stone sits on?  2) Although the pan and grits had a nice vibrating movement of the rock, the stone doesn't seem to move much when using the carpet.  Any suggestions?
Thanks in advance.
Re: Help with vibralap
« Reply #1 on: October 23, 2017, 06:25:03 PM »
Welcome to the forum!
I am moving this posting to the proper section where folks can chime in on helping you with your lap.   :icon_sunny:
-Amanda
http://www.artfire.com/ext/shop/studio/EnchantedRegalia
http://www.pinterest.com/amandabielski/
https://www.facebook.com/enchantedregalia/
Coincidence is G-d's way of staying anonymous.  -Rabbi David Abrahams
Sometimes when we are generous in small, barely detectable ways, it can change someone else's life forever. - Comedian Margaret Cho.
A man wearing a helmet defending his country should make more money than a man with a helmet defending a football!!!  (From an email message I received - so true!)
kent
    • Fine Woodwork and Lapidary
« Reply #2 on: October 25, 2017, 04:47:10 PM »
The ruff "pebbled" side may be the glue side of the pad. Perhaps just old hard glue. The soft side is what you want. If yours is overly hard from old polish try washing it with a hose and scrub brush. If you can't get the old stuff to soften to get rid of it you may need to consider a new "rug".  My "carpet" is glued to the lap so it doesn't move during the polishing stage. You'll need enough water with your polish to provide enough lubricity to allow the slab to move freely on the rug.
Hope that helps,
Cheers,
Kent
Page created in 0.085 seconds with 29 queries.
