Author Topic: Greetings - New/old member with ??  (Read 560 times)
ivanhoe
« on: February 17, 2018, 10:43:40 PM »
Not sure how this works but as a previous member I presume this will be my first entry with the new format? Glad to be able to be here and to relocate & connect with our Family Forum. If I may have a question concerning the reusing of rock saw oil?
I drained oil from a small slab saw and filtered it through several brown paper bags. The muck was removed, however the oil did not clear up. This has probably been covered somewhere on the Forum but not sure where to look? Any assistance, or suggestions with this matter would be appreciated. Thank you very much!  IV
Re: Greetings - New/old member with ??
« Reply #1 on: February 18, 2018, 05:52:51 AM »
What are you using for oil?
ivanhoe
« Reply #2 on: February 18, 2018, 08:49:54 AM »
Light Mineral Oil .... Looks to be an ultra fine dark suspension of matter left in fluid. Hope this helpss?
« Reply #3 on: February 18, 2018, 11:44:04 AM »
Since this is an issue of oil, which comes from cutting and grinding etc.  You could go here:
http://lapidaryforum.net/group/index.php?board=41.0
That's a whole section of the forum devoted to such things.
-Amanda
http://www.artfire.com/ext/shop/studio/EnchantedRegalia
http://www.pinterest.com/amandabielski/
https://www.facebook.com/enchantedregalia/
Coincidence is G-d's way of staying anonymous.  -Rabbi David Abrahams
Sometimes when we are generous in small, barely detectable ways, it can change someone else's life forever. - Comedian Margaret Cho.
A man wearing a helmet defending his country should make more money than a man with a helmet defending a football!!!  (From an email message I received - so true!)
« Reply #4 on: February 18, 2018, 03:16:47 PM »
some minerals leave a permanent color in the oil. Psylomalene and laguna lace come to mind.  i'm sure there are others.
ivanhoe
« Reply #5 on: February 18, 2018, 04:14:48 PM »
As per suggestion I'm going to repost this in an appropriate forum for further discussion, if you will? Thank you for taking the time to analyze the matter.  IV USAF 62-66
ivanhoe
« Reply #6 on: February 18, 2018, 04:38:19 PM »
Will do ... Excellent suggestion.  IV
Page created in 0.071 seconds with 36 queries.
