Congratulations to Sandsave and his Crinoid Cab!
Author Topic: Need to have slabs cut  (Read 377 times)
ILMSteve
« on: July 19, 2018, 12:31:25 PM »
I cam across some Zodiaq Engineered stone by Dupont. They call it Corian Quartz. It has a Rockwell Hardness of >85 on the "M" Scale.
It is an interesting stone with an occasional clear "quartz-like" area and some scattered glitter of red and silver.
I found 4 pieces, 4" x 4" x just under an inch thick. I think they would make some great guitar picks.
My only problem is that I do not have a saw that can cut 4' x 4" x 3mm thick slabs from them.
I am not sure how the Rockwell M Hardness compares to the Mohs hardness scale but I suspect these slabs are pretty hard material.
From what I can see diamond sawblades are required for cutting.
Is there someone here who can slab them for me? How much would it cost? I would pay postage both ways.
Re: Need to have slabs cut
« Reply #1 on: July 19, 2018, 03:51:41 PM »
Corian is a soft material comprised of arcylic and aluminum trihydrate.  It is normally cut with a carbide tooth woodworking saw.  I believe it would gum up an abrasive blade in short order.  I suppose a slab saw could be fitted with a woodworking blade for the job.  You would still face the problem of grinding to a cab.  It is normally sanded dry with silicon carbide paper.  Again, in a power tool setting it will melt and gum the abrasive.
ILMSteve
« Reply #2 on: July 22, 2018, 03:07:45 PM »
Hi SC. I thought that as well and that has been my experience with Corian as well. I checked Dupont's material spec sheet and they advise installers to use diamond saws.
I have just figured out that I can try to cut it myself. I have a tile cutter and I will try it with a thin diamond blade. I should be able to cut it to the width I need. I don't know why I didn't think of this before I made the post but I will see if it is as they say.
I'll let you see how it turns out a a few weeks. I want to get a new blade first.
Thanks.
Page created in 0.149 seconds with 29 queries.
