Author Topic: Phyllite cabachon  (Read 3256 times)
VegasJames
Phyllite cabachon
« on: December 06, 2018, 10:27:39 PM »
VegasJames
Re: Phyllite cabachon
« Reply #1 on: December 06, 2018, 10:28:55 PM »
Rough:
20180711_150951 by James Sloane, on Flickr
Close up of rough showing metallic looking texture:
20180711_151001 by James Sloane, on Flickr
« Reply #2 on: December 07, 2018, 05:40:59 AM »
That is really unique looking rough and the cab is so cool.  What's the hardness of that material?
VegasJames
« Reply #3 on: December 07, 2018, 06:13:15 AM »
From what I have read it says 1-2. Does not seem that soft to me. Maybe this has a bit of a higher quartz content. I will have to try scratching it and see. Does cab relatively easy and looks really nice in person when cabbed.
Here is some info on it:
https://geology.com/rocks/phyllite.shtml
I will be heading by there shortly on a collection trip so will probably stop on the way back and grab some more. It is a cool looking stone even in the rough.
« Reply #4 on: December 07, 2018, 04:25:13 PM »
Thanks for the info.  I learned something new (again) on this forum!
« Reply #5 on: December 07, 2018, 06:56:33 PM »
We have huge amounts of phyllite here, mountains of it and while most is blacker and more folded than your we do have plenty of the light phyllite. Ours is chatoyant when light colored and is usually a subtle gtreen. The geologists say our light colored phyllite has no graphite as the dark has and it has a high feldspar level. If yours has a lot of feldspar it could bring the hardness up as feldspar is a 5.Interesting, I will try some after  I can get up to the deposits in spring.
VegasJames
« Reply #6 on: December 07, 2018, 07:01:46 PM »
Thanks for the info. Could be a feldspar in it. Feldspar is common in Southern Nevada. I have never checked out the mine area in the daytime to see what else the mineralology is there. I actually collected all this at night with a flashlight on the way back from a trip where I pass by there.  It is definitely harder than 1-2 though.
« Reply #7 on: December 10, 2018, 07:49:36 AM »
I never knew there was a name for this. I always thought it was just a form of schist. I live in coastal Maine and have tons of this near me.i sometimes pick up pieces and put them on my windowsills because the metallic sheen is very pretty in sunlight, but it’s somewhat fragile and tends to break off along planes so I never thought of trying to cab it.
VegasJames
« Reply #8 on: December 10, 2018, 02:49:16 PM »
In a way it is kind of a form of schist. Phyllite converts in to schist. The grains in phyllite are much finer than in schist though.
It is generally listed as a hardness of 1-2, which would make it hard to cab. The material here seems to be a little harder so I am able to get some cabs out of it.
I found some golden schist powder in a wash down in California and collected a couple of bottles of it because I thought it would be great for crafts such as mixing it with epoxy then cabbing it or using it to fill cracks in stones then cab it. Anyway, if your material is too soft for cabbing there is an alternative use for it. Grind it up for crafts or put small chunks in epoxy and when it hardens cab that. Small chunks would give different orientations and thus a nice effect.
« Reply #9 on: December 10, 2018, 03:17:17 PM »
"Anyway, if your material is too soft for cabbing there is an alternative use for it. Grind it up for crafts or put small chunks in epoxy and when it hardens cab that. Small chunks would give different orientations and thus a nice effect." Yes, that's true.
Ryaly2dogs
« Reply #10 on: February 18, 2019, 10:28:09 AM »
Seen lots of phyllite but never seen someone work a phyllite cab...well done!
Page created in 0.052 seconds with 46 queries.
