Author Topic: From the other side of my world  (Read 226 times)
« on: December 09, 2018, 09:28:41 PM »
Moroccan agate pendant with square hole. 55 mm long, 8 mm hole
Re: From the other side of my world
« Reply #1 on: December 10, 2018, 06:11:17 AM »
That's different Frank, I like it. The hole brings a different feel to the piece. Might have to try something similar.
« Reply #2 on: December 10, 2018, 06:14:38 AM »
Do you have a square hole thingamajiggy for your drill, Frank?  If not, how did you do that?  It's very unique and I like it!   :occasion14:
« Reply #3 on: December 10, 2018, 07:35:30 AM »
I use hollow brass stock to make the bits.It has been a while since I have made square holes but they will become a regular part of my rotation now.
« Reply #4 on: December 10, 2018, 07:55:36 AM »
Is it a vibratory drill? Obviously not the type that turns or you’d still have a round hole even if the bit was square. I’m confused!
« Reply #5 on: December 10, 2018, 12:10:11 PM »
 Ultrasonic drills that pounds up and down with sic grit doing the cutting are capable of making virtually any shape hole.
« Reply #6 on: December 10, 2018, 03:19:30 PM »
Now that must be a very nice tool for the workshop!
« Reply #7 on: December 10, 2018, 04:43:10 PM »
I have been using them for 30 years.They are hard on your body because if you  spend the amount they cost you have to justify the expenditure by drilling and soldering new bits on and drilling.
Page created in 0.066 seconds with 41 queries.
