Author Topic: In progress  (Read 4286 times)
drnihili
In progress
« on: April 20, 2015, 01:07:48 PM »
This is the one I'm working on now.  Who knows, maybe I'll finish it.  Thus far I have a habit of working on something until it's almost done and then abandoning it.  We'll see, we'll see ....
It's about 2 inches long with a concave (8 inch radius) back from side to side that is slightly convex end to end.  That soundsmore complicated than it is, but I'm trying to be evocative of the cobble I found it as. What appears as checking in the photo may be a trick of the light as I can't find it on the stone.
Comments welcome, identification requested.  (Found on Deer Creek, Frank.)
Re: In progress
« Reply #1 on: April 20, 2015, 01:10:44 PM »
Those darn closeups find the darndest thing :) It's looking good :headbang:
drnihili
Re: In progress
« Reply #2 on: April 20, 2015, 06:25:31 PM »
I worked on it some more and, oddly, going from 3000 to buffing actually took the shine off.  I put some time on the 14k belt and got it back though.  Unfortunately there are some scratches and undercutting remaining.  They're only visible with a loupe, and close up shots, but they annoy me.
I'm wondering about dropping back to 1000 and proceeding forward more slowly.  Thoughts?
drnihili
Re: In progress
« Reply #3 on: April 20, 2015, 06:27:23 PM »
Meh, the actual color is somewhere between the two.  Teresa says the light areas are "sagey mint", the darkest areas are essentially black.
Re: In progress
« Reply #4 on: April 20, 2015, 11:31:16 PM »
Its still looking pretty good but I hate to say it, it looks like you are getting some orange peel now :( It  happens some times if you work the stone too much
drnihili
Re: In progress
« Reply #5 on: April 21, 2015, 05:58:10 AM »
Yeah, I am.  How does one rectify the situation?
Re: In progress
« Reply #6 on: April 21, 2015, 07:51:52 AM »
A stone that has exhibited orange peel ( differential cutting rates ) should never go to a felt or muslin buff. That said there are people deft enough to use a muslin buff to advantage with these stones but the buff is partially deconstructed to keep it soft ( stictching partially removed) and it is used in an extremely light manner. A more conventional approach is to use the last aggressive belt that cuts both the soft and hard components evenly then try 14,000. It may go from 1200 or 3000 diamond to the 14,000. The same concept was used with sic by hoarding and using very worn 600 grit belts as the pre polish step. The stone has chrome diopside blebs ( green ) and may have in varying proportions vesuvianite , chlorite , diopside , nephrite  and /or pumpellyite.
drnihili
Re: In progress
« Reply #7 on: April 21, 2015, 08:12:19 AM »
Thanks, Frank.  If I get a chance I'll try moving from the 1k belt straight to the 14k.  Our buffing wheel is leather, but this is the second stone I've had issues with.  How often does the leather need to be replaced?
I found another piece out on the bar with significant chrome diopside in it, but I'm still puzzling how to cut it.
drnihili
Re: In progress
« Reply #8 on: April 21, 2015, 11:23:19 AM »
Well a somewhat worn 600 SiC belt seems to have helped the orange peel.  Following up with the 14k puts a decent polish on the dark portions, but not the lighter portions.  I'll try fidgeting around with it more later, but for now I should probably get back to work.  Brilliant ideas to try would be welcome.
drnihili
Re: In progress
« Reply #9 on: April 21, 2015, 12:34:59 PM »
A bit more work and here is where I'm at.  The orange peel seems to be under control, and there's substantially less undercutting.  One of the issues I'm having now is that the chrome diopside doesn't want to take much of a polish.  I seem to do best with just a 14k diamond belt.  Buffing seems to dull the stone.
Re: In progress
« Reply #10 on: April 21, 2015, 05:04:07 PM »
The jump must be too great for the 14,000 to bring the polish up on the chrome diopside. Dry sanding is the usual cure but as you are inexperienced and this is a very distinctive stone I would hold off on that trick. Leather can cause undercutting as well.
Re: In progress
« Reply #11 on: April 21, 2015, 05:10:15 PM »
Can I raise my hand and say I think it's beautiful just as it is?   :headbang:
Re: In progress
« Reply #12 on: April 21, 2015, 05:44:43 PM »
LOL
it's never good enough Amanda; we're MEN!!!!!!! LOL
drnihili
Re: In progress
« Reply #13 on: April 21, 2015, 08:45:19 PM »
I did notice that dry sanding helped.  I agree about setting this aside for a bit.  I'm thinking I should grab a hunk of meta-stuff and play around with it, something I have plenty of.  I find I'm much more attached to three weird local rocks than to the more traditional stone such as jade.  I also need th finish that piece you said was particular granite our some such.
drnihili
Re: In progress
« Reply #14 on: April 21, 2015, 08:51:06 PM »
Thanks.  The nagging flaws don't show up so much in the photo.
Page created in 0.449 seconds with 54 queries.
