Author Topic: Chinese Carvings - need material ID  (Read 4062 times)
« on: February 23, 2016, 11:39:50 AM »
I am 100% positive none of these are Jade despite the labels where I bought them which said white Jade and brown jade etc...
I am tempted to toss them into my tumbler with polishing grit to see if the rest of the "antiquing" will come off.  Some came off with warm water and dawn dish detergent under a soft brush.
I bought these from a vendor at an antique mall back east.  I am going to take moldings of them then use the originals in jewelry.  These are double sided and I also want to know which orientation would be correct for the Chinese symbols if you know...
If you know the material ID other than "stone," or "Serpentine,"  let me know.
Thanks!
Re: Cinese Carvings - need material ID
« Reply #1 on: February 23, 2016, 03:57:12 PM »
Can't say what stone it is,  but the aging is/was done with acid, as commonly seen over here.
Re: Chinese Carvings - need material ID
« Reply #2 on: February 23, 2016, 05:12:15 PM »
Thanks Kurt for the input!
I don't think these carvings are old at all.  So it's good to know they were acid antiqued.  That explains a lot.
When I cleaned these up I had to remove what appeared to be tiny wood chips or perlite in some of the carved areas.
« Reply #3 on: February 23, 2016, 06:10:35 PM »
Tumble polished at least partially.They do not have to be stone as there are lots of very uniform faux stones around like corian.They are actually interesting.
« Reply #4 on: March 02, 2016, 02:30:48 PM »
So it should be safe then to put these into a tumbler with some grit to help clean them up a touch?  I was thinking the finest polishing grit I have.
GatorGal
« Reply #5 on: April 12, 2017, 06:38:21 PM »
A lot of these style pendants as well as Chinese carvings are made out of dyed soapstone. I would research the soapstone carvings or soapstone carved pendants. Just a little FYI, the color or dye in these will fade over time, especially if exposed to direct sunlight over time.
GatorGal
« Reply #6 on: April 12, 2017, 08:01:48 PM »
You may want to try heating them to see if the color layer is just wax.....
« Reply #7 on: April 13, 2017, 07:03:18 AM »
    Those are really nice, very nice imagery whatever they are.
No answers, just some questions. If I may ask how big are they and what did they cost each? I would wonder if they might be castings. A simple poke with a hot pin should answer that question.
« Reply #8 on: April 13, 2017, 07:34:39 AM »
If they are from over here, you can get them for as little as 5$ in the streets.
Poke it all you want, but usually the acid treatment does resemble calcification pretty well.
And yes, soapstone and other material is quite often used instead of any form of nephrite.
Even the real thing is not that expensive. Usually under 50$ as they come from undocumented burial sites that have been looted.
But its extremely hard to distinguish, and testing usually costs more than they are worth.
Real value, is only given to pieces with proven provenance.
« Reply #9 on: April 17, 2017, 02:07:39 PM »
These are around 4 inches in diameter.
Cost?  I think I paid around $15-$20 for each.
Now that I have been researching things more online I know that price is a rip off, because I found similar carvings on PandaHall.com for FIVE of them for $20 plus shipping, which weren't antiqued, though they still wanted to call them Jade, which made me laugh because I have never seen Jade in the colors they had such as red, pink, purple and orange.
Judging by the testing I have done in the process of cleaning the carvings I have, these are all soapstone or serpentine.  Nothing Jade about them.
Page created in 0.024 seconds with 36 queries.
