Author Topic: Chrysoprase maybe?  (Read 4342 times)
Sandsave
Chrysoprase maybe?
« on: August 13, 2016, 10:58:54 AM »
Sister in law sent this to me. But I'm not sure what it is.
It's soft, marks with a finger nail.
They live in Arizona if that helps.
I told them I knew a place who could ID the material so go for it!
Sandsave
tntmom
Re: Chrysoprase maybe?
« Reply #1 on: August 13, 2016, 11:10:28 AM »
Can you scratch the green with your fingernail?  Australian Chrysoprase is common with an opal rind and sometimes has dendrites in it. (Like the black stuff in your first pic).  If the green scratches then it is NOT Chrysoprase as Chrysoprase is a form of Chalcedony, gemmy hard agate.  Also.... is the green translucent?  I have a pic of a cab from Chrysoprase that looks very similar where I framed the opal and the dendrite as well as the prase.  Let me know if you want me to post it.  Also a back-lit pic would be very helpful!
~Krystee
https://www.facebook.com/kristine.gniot
Yesterday is History, Tomorrow is a Mystery, Today is a Gift.... That's why it's called The Present.
olgguy
« Reply #2 on: August 13, 2016, 01:04:59 PM »
More than likely! The whiter skinned material shown was sold to me as coming from California. The green can vary from light to medium and almost opaque.
« Reply #3 on: August 13, 2016, 01:56:00 PM »
Though your photo does look remarkably like chrysoprase, as already said: if it scratches so easily it is something else. From Arizona or northern Mexico, I'd guess smithsonite or hemimorphite, even though it doesn't have a surface with botryoidal texture. Those are harder than a fingernail, but are still weak enough to produce a pressure-flaking pattern that looks like a scratch occasionally from a fingernail. Other possibilities include gypsum/selenite and halite (both found in dry or briney lakebeds).
« Reply #4 on: August 13, 2016, 05:52:37 PM »
I thought smithsonite also. Wonderful color.
olgguy
« Reply #5 on: August 13, 2016, 06:57:04 PM »
I thought Smithsonite looked more botryoidal and bluer. I think he has the fingernail test backward, the fingernail was left on the material from the saw cut which acted like a file.
« Reply #6 on: August 13, 2016, 09:27:12 PM »
Smithsonite can be Blue, Green, Yellow, Gray, Clear among other colors.  The Smithsonite closest to me is from Cerro Gordo and it is Green. Kelly Mine in NM is famous for Blue.
« Reply #7 on: August 14, 2016, 02:10:59 AM »
The botryoidal surface is what mineral collectors are generally looking for, but it can also build up thick and solidly fill fissures in the matrix rock. Not saying that is what it is, but it's one of several possibilities that can be that color and translucence if it is softer material than chrysoprase. If there is any crystal structure, it is too small to detect in the photos.
olgguy
« Reply #8 on: August 14, 2016, 09:25:36 AM »
 It also comes in Pink and as a brownish mass. The Kelly mine, Magdalena County, New Mexico produced the largest, best formed blue-green in existence. It is Owned by Roger Williams, Encino, California. It measures 10" X 8.1" . Info from "The World's Finest Minerals and Crystals" by Peter Bancroft, 1973.
southerly
« Reply #9 on: August 15, 2016, 12:53:45 AM »
Certainly looks like chrysoprase, looks just lie the material from Mount Davies in South Australia.
David
« Reply #10 on: August 20, 2016, 01:10:26 PM »
I would be stunned if it is anything other than chrysoprase. Try scratching a clean clear green spot again and see if it really scratches or if it just was the spot you chose before was dirty or you were looking at an included spot. It looks exactly like Australian chrysoprase I gave cut in the past.
Page created in 0.028 seconds with 41 queries.
