Author Topic: Slik Slab and Trim saw  (Read 4551 times)
Gemscholar
« on: September 25, 2016, 05:44:01 PM »
So I bought a very well used, "vintage"  12"  Slik  Slab and Trim saw.  I have stripped her down, and removed most of the rust and gunk from a decade of storage.   I have a few questions:   The vintage Teel oil pump doesnt work,  no big deal, got a 1973 date on it!  So what is a good replacement?   I have read other folks post about using Little giants, and the like, but is there a problem pumping rock saw cutting oil, using a pump made for water?    I will be using oil,  probably like a Hydraulic oil at first.  But am open to suggestions.  Just cant swing the expensive oil yet.
Also,  the dang hydraulic cylinder cant be rebuilt.  i priced some replacements and Oh boy are they ever expensive. Anyone know of a cheap place to buy a replacement?   Adjustable type?
thanks in advance for any answers.  I sure am stoked to get this saw slabbing.
Thanks Ya'll
K.
Re: Slik Slab and Trim saw
« Reply #1 on: September 26, 2016, 05:45:37 AM »
You can use a swamp cooler (evaporative cooler) pump to pump oil if that's what you want to do. Can't you just fill saw to allow blade to dip into oil?  Cooler pumps are available in any hardware store in the SW (the smallest output will be sufficient for you).  You can regulate the flow without causing back pressure on the pump and will have plenty of oil volume.  I'm sure Home Depot and Lowe's show them on their websites.  "I guess they do".
I can't help with the hydraulics, but I sure would nt use hydraulic fluid as a coolant unless it was a big difference from mineral oil (so much nicer to smell and clean up).
Gemscholar
« Reply #2 on: September 28, 2016, 04:37:38 PM »
Thank you Peruano for the advice,  Yes i have decided to use Mineral oil from a local tractor supply.    And the pump for the swamp cooler sounds like an economical good choice!   The Slik Saw I bought is an Old one,  its a Drop saw, regulated by the hydraulic cylinder, and the coolant pump runs up through a tube, then divides into two tubes down alongside the blade.  Might be messy, but I''l manufacture a cover, i am sure.  thanks again for the advice.
K.
allan
« Reply #3 on: April 16, 2017, 11:48:25 PM »
Gemscholar, curious if you were able to use the mineral oil with a little giant pump? I'm in a similar situation and the Little Giant can't seem pump the oil out fast enough, although it does fine with water (so it's not the pump). I have an old 18" homemade slab saw. It has a reservoir installed on the bottom of the saw meant for a pump. Thanks in advance!
« Reply #4 on: April 17, 2017, 05:24:19 AM »
Any pump that can handle water can pump mineral oil just fine.  Just remember that the more coolant, the better.  When you start using oils with additives such as hydraulic oil you may find compatibility issues with the seals.  In any case, mineral oil is a much better choice for a lot of reasons.  Hydraulic cylinders are expensive.  That's just how it is.  In this case though, your pressure is extremely low.  Any pneumatic cylinder would work.  I've even seen it done with a home made cylinder made out of pvc pipe.
« Reply #5 on: April 17, 2017, 05:25:07 AM »
Allan,  I know next to nothing about pump designs but I know there are several.  I have a little giant for draining water from a pool cover but its working end is enclosed so I have never seen it.  A swamp cooler pump will handle the oil even when it gets pretty gunky.  It has a tiny propeller on the bottom, but in a relatively open arena (cage); thus if the pump is producing more volume than can be extruded out the outflow, the back pressure merely flows back around the sides of the intake.  I suspect that occluding (producing too much back pressure on some pumps would stress them).  We used swamp cooler motors in drop saws at our senior center lapidary shop without problems. Pinching the end of a copper tube was enough to control the outflow on each side of the blade.  I suspect that pumping a viscous liquid like oil would reduce the flow from that for a thinner liquid like water.  Thus don't expect the gallons per minute posted for the pump at the store, but then you probably don't want anything near that volume anyway.  I hope this helps.
« Reply #6 on: April 17, 2017, 08:26:20 AM »
If you haven't found a replacement hydraulic cylinder yet, try Surplus Center of Nebraska. www.surpluscenter.com. they have bunches of cylinders in their catalog, prices are good & shipping is quick.
After ordering from them, you'll get a hard copy of their catalog in the mail about twice a year. Lots of hard to find stuff, & lots more online.
Page created in 0.037 seconds with 33 queries.
