Author Topic: Material from Opal Mountain  (Read 6142 times)
StonesCryOut
« on: October 02, 2016, 01:52:22 PM »
Hey All...
I took a trip to Opal Mountain in California and collected a bunch of material that has potential to make some nice pieces. It takes a good polish and has some spots that are translucent. Let me know if have an idea what this is.
Appreciate the help!
Best,
     Gary
socalagatehound
Re: Material from Opal Mountain
« Reply #1 on: October 02, 2016, 06:19:13 PM »
There was actually an opal mine that operated in that area some time in the past.  One of the things they mined was cherry opal.
Might be a piece...
Craig
« Reply #2 on: October 02, 2016, 06:30:24 PM »
It might look different up close and personal but judging from the fracture and surface texture in your image I'd say it's chert.  It has nice colors and might polish well.
StonesCryOut
« Reply #3 on: October 02, 2016, 07:20:33 PM »
Thanks for the feedback. I took a chip and it polished up quite nicely.
Best!
Best,
     Gary
StonesCryOut
« Reply #4 on: October 03, 2016, 09:20:25 PM »
I looked up chert and it does seem to be a possibility. I also checked out cherry opal, really wish it was that. Thanks for the feedback. Put both the rough rock and the polished piece under shortwave UV and it fluoresces green. I have read that opal fluoresces green. Would chert fluoresce green depending on what it is made up of?
Best,
     Gary
« Reply #5 on: October 04, 2016, 07:17:01 AM »
      Maybe a very quick and easy hardness test is what you should try next. Most chert is pretty hard stuff. Cherry Opal can be a little harder than some precious opal but it is still softer than cherts and agates.  Maybe one of the guru's here can tell you whether a simple nail test or what to try for hardness test.   Neal
« Reply #6 on: October 04, 2016, 12:23:35 PM »
Good opal is a MOHs 6.
If you can scratch it with a pocket knife it is less than 6. Quartz is a MOHs 7 if you can scratch it with quartz (I Carry a quartz crystal in my pocket to test rocks) it is less than 7. You should not be able to scratch chert with quartz,  from the look of the uv light I would vote for opal
« Reply #7 on: October 04, 2016, 12:31:39 PM »
My test kit
StonesCryOut
« Reply #8 on: October 04, 2016, 05:53:19 PM »
Thanks for the guidance!
Best!
Best,
     Gary
« Reply #9 on: October 04, 2016, 09:00:27 PM »
Looks like a couple of the chipped areas show conchoidal fracture appearance. That would be another clue for opal.
« Reply #10 on: October 04, 2016, 09:57:29 PM »
Definitely quartz family from the conchoidal fracture.  But all opal rough I've ever seen had a waxy, shiny luster, not the rough non-reflective dull luster in the image.  Hardness testing should help sort it if done correctly.
« Reply #11 on: October 05, 2016, 07:52:48 AM »
Love this forum. Just learned something. Or re-learned something I'd forgotten since reading the book.
Conchoidal fracture in opal apparently has a characteristic specific to opal only. On pg. 11 of "The World of Opals" (Eckert) the author says the conchoidal fracture in opal frequently shows, under slight magnification, radiating lines with small triangular tips on one side only. Makes them look like "harpoons", he says.
Now, since he says "frequently", I guess they're not always present, but if they are it's an identifier for opal. Now I'm gonna' have to go pull out some rough to see if it shows up under 10x magnification.
Also stumbled across a reference from somewhere else that says there's some professional debate about whether the fractures shown in opal are conchoidal or sub-conchoidal. Now I'm gettin' a headache...!
« Reply #12 on: October 05, 2016, 11:43:51 AM »
Interesting comments Vince.  I just happened to have a chunk of Owyhee Blue Opal handy when I read your post and made a couple of quick images.  Yes, "harpoons!"  I agree with Eckert that opal shows sub-conchoidal fracture, not those perfect clamshell divots seen in harder cryptocrystalline quartzes.
This piece shows both the waxy luster I find typical of both common and precious opal, and the "harpoon"-like lines.
« Reply #13 on: October 05, 2016, 08:08:27 PM »
Wow - that's too cool. Thanks for posting the photos! That's a perfect illustration (arrrgh) of why this forum is such a great place to learn. You posted the images of a dry factoid I'd read and since forgotten. Now everyone who sees those photos will have another bit of knowledge in their toolkit.
Page created in 0.041 seconds with 47 queries.
