Author Topic: Vise Replacement options for 10" Raytech?  (Read 5873 times)
TRG
« on: March 01, 2017, 03:54:13 PM »
Hey folks! I was wondering if anyone knew of a replacement or modification from the horizontal clamping vise to a vertical closing vise for an older 10" Raytech saw.   It has a faucet handle to tighten the vise and I can't seem to get it to hold the rock with enough strength to guarantee it won't slip out and damage the blade. I thought I can clamp one of the vertical vises in there but I would lose the height on the size stone I can cut. I'm already concerned about anything in the vise coming loose so in general doesn't seem to be the answer either. I wondered if I'm going to have to change out the screw feed and everything. It just seems like I will have to use the saw for smaller vein agates and smaller rough then the other 10" saw I have cuts if I don't figure out another option. Thanks for any help on this!
Re: Vise Replacement options for 10" Raytech?
« Reply #1 on: March 02, 2017, 05:32:18 AM »
Can you post up some photos of your current setup?  If its a matter of not feeling like your vice is tightened enough, there may be solutions that do not involve a new vice.  I need to clarify for my thinking the exact vice you have. Different folks describe the workings of a vice in different words. Are the jaws of the vice vertical or do they contact the stone from the top and bottom?   Are you using wedges to tighten up the fit of the stone against the vice jaws?  I keep an array of wedges cut from hardwood scrap that I use to shim any major areas where the rock is not snuggle contacting the vice surface and then tighten a tad more to lock them in place.  Can you replace the faucet handle with a pair of locked nuts on a similarly threaded bolt so that you could use a wrench to tighten?  Have you tried stubbing your stones so that you have a totally flat surface to clamp against i.e. with a 2x2 or similar wood block?
TRG
« Reply #2 on: March 02, 2017, 08:14:29 PM »
Peruano, Thanks for the ideas! I might change out the faucet handle with a wingnut. I haven't used the wedges on this piece. I will get some pics and will go from there to see what you think.
jerrysg
« Reply #3 on: March 03, 2017, 04:32:01 PM »
I have the same saw and the same issues with the vise. Raytech has sold their saw business to Scott Manufacturing in Littleton, Co. (303-887-6942) who also makes the Raytech-Shaw faceting machine.
One of the things that I recently did which improved the vise was to replace the wood jaws on the vise.  Rick Scott at Scott Manufacturing was very helpful with the ordering of the parts. They don't have a web page so you need to call to order parts.
My usual procedure is to only clamp the rock in the vise for the first cut. I then clean the oil off and glue the rock flat to a piece of granite tile which is clamped in the vise for all subsequent cuts. I use the faucet handle on the inside screw to bring the rear jaw into contact with the rock.  The real clamping force should be applied with the outer screw with the wing nut.  If necessary, a wrench can be used to really tighten down the wing nut.  I use popsicle sticks, tongue depressors, wood shims or anything else I have available to get uniform clamping on the rock for that first cut.
I got some 4"x4"x1" granite tiles from a tile outlet and have cut them either in half or quarter to get pieces to super glue to the rocks. They clamp well because they are square to the vise faces and they slip under the clamping screws.  Some people use wood blocks for this purpose but I like the tile because 1) they are what the saw was designed to cut, 2) they don't absorb oil and so are reusable and 3) with a simple wipe with solvent, they can be immediately glued to the next rock and I am ready to put them in the saw in about 2 minutes.
« Reply #4 on: March 03, 2017, 04:49:31 PM »
Everything said above is well grounded.  If the wing nut works because it is jammed against a regular nut, why not use another hex nut instead of the wing nut and have the option of using an appropriate wrench (saves the fingers).  Tile work as stubs, but so too do 2x2 wood or other sizes of wood blocks.  They are reusable when a fresh surface is cut on one end and they are easy to remove by cutting close but not touching the remaining stone with a hack saw (the thin sliver of wood and wood glue soaks off in soapy water in a matter of 1 or 2 hours and you did not need to cut the stub off with the saw. I have a basket of wood stubs that I glue up a dozen at a time or so and eventually use as fire starters for my wood stove.   Different strokes and they all work.  That is not the ideal vice in that it does not really gravitate to remaining parallel, but with adequate tightening and wedges (I'd say use hard wood wedges, odd angles but the thinner the better to allow you to wedge into thin spaces).  The vice will work for you but you probably will have to fumble with its idiosyncratic design.   You may need to add a piece of wood or other block to hold the jaws somewhat parallel which can help get a better (more secure purchase) on the stone.  I hope our encouragement helps.
TRG
« Reply #5 on: March 04, 2017, 10:02:51 AM »
Thanks Jerrysg.. You beat me to it with the pics. That's the same vise set up as mine. Thanks for the tips on the order in which you lock it in and that method for gluing to a square tile.  Peruano, thanks again. I am going to try out the wedges and some other things and do my best to make it work.  What kind of glue do either of you use for quickest and strongest hold results?
jerrysg
« Reply #6 on: March 04, 2017, 08:34:12 PM »
I use the gel super glue with the accelerator. Either a woodworking store or a large hobby shop should carry them.  Here in the Tucson area, I have bought from both.  Generally the hobby shop is a little cheaper. The accelerator (catalyst) comes in a spray bottle but I don't spray it. I just take the sprayer out of the bottle and use the dip tube to spread a little of the accelerator on one of the surfaces - the super glue goes on the other. Bring them together and the bond will develop within 15 seconds. I  did a post on using this technique to mount cabs on wood screws.
 http://lapidaryforum.net/group/index.php?topic=1859.msg14588#msg14588
Jerry
« Reply #7 on: March 05, 2017, 04:49:50 AM »
On wood stubs, carpenter's glue works great - even on smooth rocks.  I'm using Gorilla Glue (carpenters glue, not the foamy stuff) at present but Elmer's or the generic brands work as well.  If you have a choice you need not choose the waterproof/resistant stuff.  It softens in about an hour or two if the slice of wood is thin and is relatively easy to clean off with an additional soak as necessary.
« Reply #8 on: March 06, 2017, 05:04:32 AM »
I just opened this pdf of instructions for a Raytech trim saw and noticed the "detailed" instructions on how to adjust and use the vice that is giving you concern.  I thought I'd point it out to you in case it adds anything to your understanding.
 http://www.raytechgemprocessing.com/support/pdfs/gems/saw.pdf
TRG
« Reply #9 on: March 06, 2017, 12:47:42 PM »
Thanks Jerry and Peruano..  it's good to know some different options. I have some end cuts I've wanted to slab at the same orient and this will be perfect.  I tried out tightening the faucet handle first and then the outer wing nut and that seemed to be key.  I got some slabs cut yesterday with the saw and didn't have an issue.  Glad to have the instructions for the saw now too.. just picked this one up used a few months ago
Page created in 0.031 seconds with 39 queries.
