Author Topic: What is it? Can I use it for opal doublets?  (Read 2649 times)
« on: June 05, 2017, 09:05:56 PM »
Hi, I was going to buy a couple more slabs of black basanite or jade for making doublets, but then I remembered I had this rock, but I can't recall what it is, if I ever knew. Can you tell me what it is and if it could be sliced somewhat thin and used for that or not?
I found this a couple of years ago on the beach in either Cape Elizabeth or South Portland, Maine.
I have one picture dry and one wet and also showed the side where there is a rough spot that seems less smooth than the rest.
I tried to scratch it with a stainless steel knife and it left scratches the color of pencil marks, so I can't tell if that is the stone getting scratched or the knife leaving behind some metal! If it is scratching the stone, it isn't by much.
It feels quite heavy and smooth to touch.
Re: What is it? Can I use it for opal doublets?
« Reply #1 on: June 05, 2017, 09:14:18 PM »
Normally the silver like graphite is the knife leaving material behind.  Could be a very dark jade or similar tough stone.  The next test of jade would be to see if it can be scratched by a Quartz crystal.  The only issue if it is Jade is that a lot of the very dark material is only due to the thickness of the material.  Upon cutting thin enough for triplets it may start to have a more distinct Green hue.  That however would only be known once cut.
« Reply #2 on: June 05, 2017, 09:23:10 PM »
Quartz scratched it.
« Reply #3 on: June 05, 2017, 10:08:39 PM »
Well the scratches tell me that it is in the range of Jade and the image certainly has the look of a nicely worn Jade cobble.  I will leave the rest to the many people on the forum that have SO much more Jade experience than I do.  The Jade should have a cold feel on touch even when it is warm out and if you look closely at it with a loupe and a strong light pressed up to it to light the inside you should see some fiber like translucency to it although depending on how many inclusions are creating the dark coloration that might be hard to do.  My vote is more Jade than high end Serpentine.
« Reply #4 on: June 06, 2017, 06:42:18 AM »
Like irockhound said, as long as it's not translucent once you have it thin enough to back a doublet, it should work just fine.  You can basically use any dark material to back a doublet.
« Reply #5 on: June 06, 2017, 04:51:28 PM »
Thanks for all the information! I will try it.
« Reply #6 on: June 06, 2017, 06:41:02 PM »
There is black amphibolite around coastal Maine, so I suspect that or another amphibole group member. The hardness sounds right for your piece (amphibolite can be one of the constituents in nephrite jade).
I agree with others who said that it should be fine as a backing.
Page created in 0.037 seconds with 30 queries.
