Author Topic: Potstickers  (Read 2981 times)
Potstickers
« on: November 01, 2014, 02:03:11 PM »
All this talk of curry is making me hungry.  So I thought I would throw in a good basic potsticker recipe.
The beauty of Potstickers is that you can vary the type of vegetables by your own tastes.  You can also hide vegetables really well this way with fussy eaters.  It's a great way to hide beets, Chard, squash, parsnips and anything else that you can easily grind up in the food processor.  I've even thrown in broccoli and cauliflower!
My basic filling recipe:
Into the food processor I put...
One small yellow summer squash, cleaned and cut into chunks.
A one inch by one inch chunk of fresh ginger root, peeled, chunked up.
One stalk of celery, cleaned and chunked.
One large carrot, peeled and chunked.
Mushrooms of choice, cleaned and destemmed.
I chop all that in the food processor till it is finely chopped but not pureed.
I then dump that into a mixing bowl and add:
one pound ground meat of choice (I use turkey)
One bunch green onions/scallions diced
One cup rice flour
Two tablespoons minced garlic
Two tablespoons hoisin sauce
two-four leaves of diced or shredded Chinese or Savoy type cabbage.
I mix everything together thoroughly.
Then I use about one to two teaspoons of mixture into the center of a pre-made wrapper.
You can make your own dough, and I have done so, but it's time consuming and some nights I just don't feel like spending three hours in the kitchen.
I fold up the wrapper using a pleating method and arrange each finished potsticker into a moderately oiled frying pan.  A couple tablespoons of olive oil typically is all I need.
Once the pan is full I put the pan on high heat and fry about 5 minutes or until the bottoms start to brown.  Depending on your stove this could be a shorter time or longer time.
Then I take a tumbler of filtered water and dump it straight into the fry pan.  Yes it's going to spit and spatter and scream at you.  Cover the pan and let the potstickers now steam for about 15 minutes.  The steaming time depends of course on the meat you are using.  In a purely vegetarian variety I steam for about ten minutes.
When the water has mostly evaporated remove from the heat and let sit a moment.  Serve with your choice of dipping sauces.
Variations:
In place of meat use one small eggplant peeled and diced up and tofu diced up - enough to equal the volume of one pound of meat.  Proceed as above but adjust cooking time.
Yes this is how I get vegetables into my Husband.  I use the same filling for eggrolls as well, just add extra Chinese Cabbage.
I find I always have filling left over after making up a full pan of potstickers.  I simply freeze the remaining filling for use in more potstickers or in eggrolls.
For the adventurous who like spending hours in the kitchen and want to make your own dough and roll your own wrappers.
2 cups all purpose flour
 I put that into the food processor and then slowly add water - roughly a half cup, adding a bit more as necessary till a dough comes together.  The dough should not be overly sticky.  If it is, add more flour.  Dump it out onto a surface, knead it a couple minutes then cover it and let it rest about 10-15 minutes before starting.  It is however adviseable that it is better to have a dough that is a bit to wet than one that is to dry.
Break off piece from the dough about the size of a ping pong ball.  Roll them out flat till they are roughly 1mm-1.5mm thick.    Turn the dough as you roll it so the shape becomes a fairly uniform circle.  Proceed to fill as per instructions above and cook accordingly.
For pleating instructions I have found several online sites that give diagrams on various ways of folding them.  I use a multi-pleat fold called "Har Gow," which is Cantonese in origin.
Minkos61
Re: Potstickers
« Reply #1 on: November 01, 2014, 06:09:13 PM »
Yum Yum this is worth a try!
Thanks Amanda.
Ernie
Re: Potstickers
« Reply #2 on: November 01, 2014, 07:49:49 PM »
More traditional potstickers have vastly more meat in them.  Typically a ratio of 3 parts meat to one part vegetable.  I tend to put that almost in reverse because I'm trying desperately to get my Husband eating healthier.
Bentiron
Re: Potstickers
« Reply #3 on: November 04, 2014, 02:42:57 PM »
Eating healthier? What you want him to avoid diabetes, cancer of the bowel plus all those other diseases associated with obesity just so he can have a long happy life with you? Oh, OK, I guess you can do that for him. :hello2:
Re: Potstickers
« Reply #4 on: November 04, 2014, 05:46:15 PM »
Yeah Jerry I do want him eating healthier!  :icon_cheers:
It's bad enough since I moved in with him he has gained 100 pounds where I've stayed in the same 10 pound window.  Obviously someone likes my cooking a wee bit to much.
Yes I want him to avoid diabetes.  It's bad enough I'm pre-diabetic, I don't need him getting that way too.
So the more vegetables I can get him to eat the better.
I've already taken red meat out of his diet since it makes me sick when I eat it (My intestines do not get along with it at all).
I've fed him 99% vegetable potstickers flavored with chicken broth concentrate and he never knew it!
So yeah I'm desperately trying to get him to eat better.  Now if I could get him to stop eating junk when I'm not looking or when he is at work, it would be a vast improvement!
Re: Potstickers
« Reply #5 on: November 04, 2014, 05:48:36 PM »
I love all veggies, raw, steamed, boiled;not too much water so you can drink the boilings, fried, and barbecued. The fresh out of the garden variety < I like the best of course but living up here we have to import the fresher stuff in the winter of course so I try to keep an open mind about farming practices and trust them to give me something I can recover from come springtime LOL
Re: Potstickers
« Reply #6 on: November 06, 2014, 07:44:38 PM »
The only pot stickers I eat are the ones that I buy frozen from the grocery store and they are awesome. As good as I used to get at the Chinese restaurant in Texas.
NONE come close to the ones I ate while in China though. Some of the best eating I have come across in my lifetime. Not sure how much they shortened my life though. Some of the food there is scary because it is hard to tell what some of the ingredients were. Too good to care though.
Re: Potstickers
« Reply #7 on: November 06, 2014, 08:04:17 PM »
Jim traditional potstickers and wontons are usually filled with a mixture of pork, cabbage, ginger, onion, corn starch or rice starch.  That is pretty much what you'll find.  Granted that's not to say in some areas they don't use other meats.
I've had some store bought frozen ones that were chicken with bean sprouts and those were good too.
The trick is in cooking them.  To get that traditional browned bottom that is crispy and the rest of it chewy, you need to first pan fry the potstickers in a touch of oil for 4-6 minutes and then quickly add in enough water to the pan to partly cover the potstickers, then you let that boil and steam the potstickers the rest of the way.
I did a batch tonight even, took some filling from the freezer I had frozen from last time, added chopped cabbage to it, more ginger because Peter is fighting a cold, and diced up turkey bacon for some extra protein.  They went over well, Peter ate his fair share!
Re: Potstickers
« Reply #8 on: November 07, 2014, 05:51:59 AM »
The browned bottom is the way they were in Texas and probably all of the US but the area of China I was in did not have that. Different areas in China have food prepared in many different ways. In the north of China "Beijing" they prefer rice but in the south where I was they prefer rice noodles.
I also loved the rice noodles over plain rice. They cooked them in a 55 gallon drum full of water with a fire under it. To make the noodles they used a thing like a huge garlic press and squeezed them out slowly into the water so they would not stick together. I would guess they used rice flower and water mixed thin enough to squeeze out but thick enough to not fall apart. Not sure what the difference is but they were much better than plain rice. I would love to go back just for the food.
Re: Potstickers
« Reply #9 on: November 07, 2014, 06:22:42 AM »
I can wager yours were prepared with a steaming process and no frying in there then.  I tend to make mine in a manner that is more Cantonese.
Now of course my Husband wants me to make this one kind of dumpling that when you bite into it, broth comes out and greets your tongue.  I have a recipe for it, not sure I really want to go through the trouble of creating them though.  The making of the gelled broth that goes into them looks like a process that takes a few hours and of course chill time.
Page created in 0.021 seconds with 39 queries.
