Author Topic: Do I have a wet/dry grinder and don't know it?  (Read 6942 times)
John Robinson
« on: August 15, 2017, 10:22:40 AM »
I am scrounging for equipment to get started and  I need a grinder. I have this old Craftsman grinder with a sealed motor, that is, there are no vents or holes in the motor casing. Is there a way to find out if  it a wet/dry grinder without the plumbing?
Of course I will still need to buy two expensive lap wheels but I need something to use while I am saving up for a Diamond Pacific machine.
Rockoteer
Re: Do I have a wet/dry grinder and don't know it?
« Reply #1 on: August 15, 2017, 12:10:48 PM »
Pictures sure would help.....
« Reply #2 on: August 15, 2017, 01:39:58 PM »
Look on the information plate for TEFC.  It stands for totally enclosed fan cooled.  It still would not be the proper choice for wet grinding as the electrical connection will still be exposed.  Belt driven is the right way.
lapidaryrough
    • www.lapidaryrough.com
« Reply #3 on: August 15, 2017, 02:52:23 PM »
Note to all
  GFI, trips at  100 mill-amps.
  GFIC trips at  10 mill-amps.
  Which is the LIFE saver?
  https://www.osha.gov/SLTC/etools/construction/electrical_incidents/gfci.html
Silicate life form
Rockoteer
« Reply #4 on: August 15, 2017, 05:15:45 PM »
10
John Robinson
« Reply #5 on: August 15, 2017, 07:27:45 PM »
I will upload pix and the info on the motor' s plate
« Reply #6 on: August 16, 2017, 06:35:30 AM »
Gfi (ground fault interrupter) and gfci ( ground fault circuit interrupter) are basically the same device
The common household type trips at 4 to 6 ma. 10 to 20 ma gfci we use on things like heat cable for snow melt (costs are around $125.00) 20 to 30 ma are what is used for something like a house boat.
A 100ma is what is typical found in an industrial 480 volt three phase main breaker. And are expensive ($1,000.00 or more)
 Now that I have everyone confused you Just use your standard residential grade gfci circuit breaker, receptacle outlet or you can get a plug in type
John Robinson
« Reply #7 on: August 16, 2017, 08:55:25 AM »
Craftsman 1/4 HP
3450 RPM
Model 11519500
Also have
TriStar 5 speed drill press
1/3 hp
Model dpmini
and I do not know if it is piece of lapidary equipment
*RenderedContent-18F912DB-CAAF-4DE3-B3D3-8C87C1D9C987.JPG (118.75 kB . 1136x852 - viewed 751 times)RenderedContent-5D763DA5-D410-46D7-8727-DF712DE6330C.JPG
lapidaryrough
« Reply #8 on: August 16, 2017, 09:03:32 AM »
1750 RPM for a lapidary grinder is best.
Silicate life form
Rockoteer
« Reply #9 on: August 16, 2017, 09:33:57 AM »
This is not a piece of lapidary equipment.  I am sure the wheels are for metal grinding like lawn mower blades.  The rpm's should be no more than 1725.  I, personally, would not even consider using it for my rocks.  THIS IS JMHO
« Reply #10 on: August 16, 2017, 12:10:52 PM »
Commonly referred to as Craftsman block grinder.  It has a following as a very good home use grinder.  Definitely not meant to be used wet.
« Reply #11 on: August 16, 2017, 03:29:54 PM »
    Anything can be a lapidary tool with a little work. You can take the grinding wheels off and replace them with pulleys. Step down the RPM's and drive a grinder, polisher or other Lapidary machine. That is a great unit with lots of HP and ball bearings....  Find a nice arbor to use with it and you are in business. You could even use it to power a saw. Put on the thinking cap and good luck,  neal
John Robinson
« Reply #12 on: August 17, 2017, 02:37:08 PM »
Thanks for all the responses!
Rockoteer
« Reply #13 on: August 17, 2017, 09:42:44 PM »
Do you really think that 1/4 hp is enough?  I suppose if you stepped it down with pulleys .... but then you have to drive another arbor.
« Reply #14 on: August 18, 2017, 09:28:29 AM »
   Yep, 1/4 horse will do many but not all things. Turning any type of polish or sanding wheel that is not huge is easy. With an arbor and water trays you can be in business. Or the Lortone saw kits that do not come with motors are a good buy. I have purchased a 6 and 10 inch stainless diamond saw kit and they work great.
Page created in 0.029 seconds with 46 queries.
