Author Topic: Intrusions in big crystal  (Read 2177 times)
John Robinson
« on: August 23, 2017, 10:23:33 AM »
I have this end cut of a eight inch crystal and there are two areas of it I wonder about. There is a silvery mass (bottom right) that looks metallic but shows no crystaline pattern. There are also little prismatic flashes, some deep within the quartz.
Are these just attributes of fractured quartz
Re: Intrusions in big crystal
« Reply #1 on: August 23, 2017, 11:21:42 AM »
That's a big xtl. Yes, those are formation stress fractures. Sometimes metal, oxides or other minerals get into and fill those veils. I have a little collection of such inclusions that I find fascinating. The rainbows are a thin-film interference effect that is sometimes caused by a micro-thin layer of water or other material trapped in a veil. If that material is liquid and eventually evaporates after being freed, then the rainbow will also disappear. However, sometimes, if you don't cut into the veil, the TFI rainbow effect will last.
John Robinson
« Reply #2 on: August 23, 2017, 09:59:00 PM »
Yes could I use  core bit to catch one of the rainbows in a cab? It
« Reply #3 on: August 24, 2017, 07:34:29 AM »
    It is also possible your rainbows are simple refractions of light from the fractures in your crystal. The second photo appears to show two fracture lines, one on each side of the rainbows. If you cut the stone correctly you may be able to save the rainbows. The crystal may also just fracture when you try to cut near what appear to be fractures.
John Robinson
« Reply #4 on: August 24, 2017, 06:28:32 PM »
Thanks! I have several end cuts that I am looking at to see if another slab can be cut from them. It is a tough call as the guy who owned them previously seem to know when to give up. I think though if I can cut at right angles from the original cuts I can salvage a few cabs from each slab (?)
Page created in 0.023 seconds with 26 queries.
