Author Topic: Lortone 3A tumbler  (Read 4385 times)
William Phillips
Lortone 3A tumbler
« on: December 13, 2017, 12:13:25 PM »
 I have a Lortone 3A tumbler, the barrel won't turn.  The motor runs and the drive rod turns, however the barrel won't roll.  I have the barrel half filled and I weighed the material I put inside (About 1 pound plus water to cover the rocks). Any Suggestions
Thank You
Bill Phillips
lapidaryrough
    • www.lapidaryrough.com
Re: Lortone 3A tumbler
« Reply #1 on: December 13, 2017, 01:22:28 PM »
http://www.lortone.com/pdf/Model_3A_PartsList_Instructions.pdf
      link for manual for 3 A tumbler.
    Consider pillow block bearings, For your next upgrade.
    Vibra-sonic's great for 220 grit and finer - rotary tumblers for 40/70 through 80 grit ( 80 grit breaks now fast so let it run for three weeks JUST keep a good paste wet , and more 80 grit water as needed. Just let it break down for three weeks, sort for the barrel, keep different barrels for coarse runs / other polish & fine grit runs.
  Dad  gave me a LS-18 in 1981, Fine saw though - Lortone fine if you use them twice a year for life. Or daily uses ( OLD HighLand-Park )   with light PM over 3 decades. Funny how lapidary has gone from the yard of piles and buckets. to a shoe box under the kitchen table.   with a 8'' diamond pacific  Titian.   "GOT SLABS?"
Silicate life form
William Phillips
« Reply #2 on: December 13, 2017, 02:36:44 PM »
Thank You,
 I used the link to the Lortone  PDF
 I took the cover of and found the drive pulley was full of rubber dust. I cleaned it and I'm off and running (tumbling).
My parents also had a 20 pound tumbler, which I am also using. Its a Lortone they bought while I was in the Army.
Thanks again
Bill Phillips
robirdman
« Reply #3 on: February 26, 2018, 03:21:58 AM »
I just had a similar problem with my decades old Lortone gallon tumbler, not used in years.  Lortone said maybe the belt was too loose, and when I pressed in on it, the barrel turned.  There were screws to move the motor and I adjusted and this worked.
Ryaly2dogs
« Reply #4 on: February 26, 2018, 05:56:22 PM »
A new belt at about $3 plus shipping from the Rock Shed also does wonders. I also use duct tape around where the lid meets the barrel as this action over time can wear to a polish and loss of friction results in slipping but no rolling.  Again a few cents and wham, back on track.  One has been going for about 2 years straight now on successive loads.  I have tried several times to kill my Lortone's but they keep plugging.
Page created in 0.024 seconds with 26 queries.
