Author Topic: Little Torch  (Read 8167 times)
Neural
  • Opal Addict
Little Torch
« on: July 14, 2018, 04:29:33 PM »
So, I have gone through all of my jewelry making stuff, and separated out a bunch of things to keep, and things to sell.
I have a question about the Smith's Little Torch that I used to use for Silver soldering.
It's a propane/oxygen setup.  Would it be possible to use it for aluminum brazing?
I'm not looking to weld aluminum, just brazing to attach aluminum frames to aluminum wall art.
If it is, is there anything different I would need beyond the typical soldering set up?
Re: Little Torch
« Reply #1 on: July 14, 2018, 04:35:36 PM »
In the presence of heat and oxygen aluminum will turn to aluminum oxide.  It will loose coherance and all you will have is powder.  Aluminum can only be welded with an oxygen free heat source and protected from atmosphere.  That means the only practical means is MIG or TIG unless you happen to have a powerful laser.
kenny
Re: Little Torch
« Reply #2 on: July 15, 2018, 08:31:39 AM »
Yes you can you just have to be careful not to get it too hot it will solder/braze just like copper etc. I do it quite a bit but mainly use propane or mapp gas and aluminum rods it makes for a very strong joint. It is actually very easy. I have a smith torch but it's packed away and I haven't used it but will be if I can find it so I can get a finer flame for pin point welds. There are lots of YOUTUBE vids on it. Here are the type of rods used I haven't used this particular brands I got mine from ACE and then some from HF didn't really notice much difference in brands.
https://www.amazon.com/230x2mm-Temperature-Aluminum-Welding-Soldering/dp/B0736NLM91/ref=sr_1_6?ie=UTF8&qid=1531668812&sr=8-6&keywords=aluminum+solder
Mud
  • I was born wet.
Re: Little Torch
« Reply #3 on: July 15, 2018, 08:54:36 PM »
x2.  My experience is right in line with Kenny's.  One tip is to pre-heat the pieces to be brazed in the oven, bringing them up to temperature will be that much easier/faster.
Neural
  • Opal Addict
Re: Little Torch
« Reply #4 on: July 15, 2018, 11:42:54 PM »
Ok, thanks.  For what I'm thinking of using it for, it might be better to go with a MAPP torch, etc.
Page created in 0.022 seconds with 29 queries.
