Author Topic: Agate type chart  (Read 6526 times)
Kaljaia
Agate type chart
« on: September 23, 2018, 10:21:49 AM »
I thought it would be a fun project to see how many different types of agate I can find from a single location :P make up a little ID chart for the place. I'm still putting together the list. Here's what I have so far:
Dendritic
Banded
T-egg core
Flame agate
Agate geode
Moss agate
Waterline agate
Botryoidal agate
I have tube agate and one small piece of plume too, not photographed yet. Any others I'm missing? I'm hoping to make a easy-to-use key for the local kids and will be improving the photographs after I put the set together.
- Erika
Re: Agate type chart
« Reply #1 on: September 23, 2018, 11:49:42 AM »
Nice variety. Is banded a banded and or Fortification Agate?
Kaljaia
« Reply #2 on: September 24, 2018, 10:14:22 AM »
I'm not firm on the difference between the two, honestly. Is it a difference in appearance or formation? I've been using the terms interchangeably but if they are two separate materials I'd love to learn more!
- Erika
« Reply #3 on: September 24, 2018, 01:45:42 PM »
This is how I have always understood it.  Although fortification is almost always banded, banded is not always fortification.  Fortification refers to concentric bands around a central point (like walls around a fort, hence the name fortification).  Banded agates may have bands of differing shapes and sizes that wander to and fro but never create a fortification effect.  Your agate above I would classify as fortification agate, but banded would technically be a correct description for it as well.
« Reply #4 on: September 24, 2018, 03:28:43 PM »
In addition to the fortified (resembling the plan of a 17th or 18th century fort) and non-fortified (wavy type banding), I've incorporated those mentioned with some other types that come to mind:
BANDED
· fortified (bands enclose a large area, resembling the floor plan of a 17th or 18th century fort);
· plain banded (a pattern of wavy lines);
· lace (lots of enclosed bands);
PATTERN
· dendritic (tree or shrub-like branching formations);
· plume (ostrich feather-like formations);
· moss (thread-like formations);
· picture, landscape or scenic (combination of patterns that resemble landscape paintings);
· orbicular or eye (contain ball-like inclusions);
· poppy agates (I'd include the so-called "Ocean Jasper" and some translucent poppy-type jaspers as agates);
· cloud (very soft, fuzzy bands and swirls);
· flame (fire-like plumes);
· waterline or onyx (parallel horizontal banding);
· Fischer (an artificially induced dendrite-type formation);
OPTICAL PHENOMENA
· iris (very, very tight banding that breaks light into a rainbow spectrum when backlit)
· fire (botryoidal formations containing thin layers of iridescent goethite and/or limonite);
· parallax or "shadow" (banding in transparent agate that gives a 3D effect);
· turtleback (botryoidal formation with very fine/invisible banding that forms a turtleshell type pattern when backlit);
FORMATION
· geode (a roundish thunderegg, vesicular agate or similar with a hollow center);
· thunderegg (a rhyolite nodule in a volcanic flow in which a gas chamber later filled with agate, often under great pressure);
· botryoidal or grape (resembles a grape-like cluster of orbs);
· mammillary (resembles udders);
· enhydro (contains bubbles of ancient water);
· vein or seam banded (pattern follows the outline of the crack which held it);
· amygdular (roughly round agate or geode formed in gas bubbles within volcanic host rock);
· membrane (filled with broken bits of the initial banded layers);
· polyhedral (a type of agate replacement where the agate follows the form of a previously dissolved polygonal mineral crystal);
· polymorph (agate that has replaced another mineral);
· sagenic (agate containing sagenite-type needles);
· agate casts (limb, bone and similar casts of once-living organisms);
· oolitic (contains small orbs; orbs larger than 5mm are pisolites, rather than oolites);
· brecciated or shatter (fully formed agate that has shattered and then re-healed);
...probably more. And it probably should be mentioned that some agates are combinations of two or more of these features.
Page created in 0.031 seconds with 29 queries.
