Author Topic: Rainforest Jasper cab I finished last night  (Read 1976 times)
denverkris
« on: September 26, 2018, 08:54:47 AM »
Per some feedback I tried to get a crisper, more even girdle on this one. I really struggled with pics for this, out of about 50 this is the best one so far :/
Re: Rainforest Jasper cab I finished last night
« Reply #1 on: September 27, 2018, 07:48:47 AM »
Shape and dome profile look good from this angle. Girdle looks consistent and fairly sharp/crisp. Biggest consideration once the girdle is even all around is polishing without rolling over it from either direction.
Getting a dome profile perfectly symmetrical and polishing both the dome and the girdle without touching that girdle line are two things that take a while to get comfortable with. Do you use a visor for magnification while cutting?
For quick-and-dirty photos you can use double-faced tape to stick the cab onto a flat surface. Camera will be forced to focus on the stone, and you can tip or tilt it however you want. Look up "photo gray" or neutral background color to avoid weird color balance effects.
If you want to do professional looking shots, there's a tutorial type thread on here somewhere by bobby1 on how to construct a "floating" cab setup.
denverkris
« Reply #2 on: September 28, 2018, 10:48:15 AM »
Hey, thanks for the input! Ya I saw that floating cab tutorial, it's on my list (I still have a full time job). I do use a visor when I'm cutting. Man that sucks when you're all like "this shit looks good" and then you put on that 5x. And I swear they look so much more polished (shiny) in person. I do have some more polishing stuff on the way (my rough leather pads just arrived), as well as some higher grit belts (only going to 3000 right now? I do have some 14k paste). Should I wet the stone with oil or water or something before taking the pic?
Also, do you mean i'm supposed to try and polish without touching the girdle? As in, so I don't dull the girdle line?
« Reply #3 on: September 28, 2018, 07:54:16 PM »
Hi denverkris,
I think my hubby misspoke a bit with that.  I think he meant sanding instead of polishing.  When you are sanding the dome (280 & 600 grit wheels) try not to roll over the girdle line because that will cause your girdle to become uneven.  As you progress up the grits, it's less critical because the higher grits take so little stone off.  1,200 will still take enough off to ball it up, but 3,000 won't bother it much unless you keep doing it.  Once you hit polish (14,000 and above), there is no longer a real need to worry about it.  If you use one of the oxide polishes, also no need to worry.  I actually always give my stones a once over with cerium oxide, and I always go over the girdle line with it.
« Reply #4 on: September 28, 2018, 08:24:45 PM »
Yeah, once you get to 3000 you don't have to worry about rounding the edge of the girdle line. I still try to keep the lap or wheel spinning outward from the dome and over the edge, as opposed to having the wheel/lap rotation moving across the stone from the edge toward the center of the dome. If you're spinning it on a dop stick you just have to watch the angle of the cab relative to the wheel.
denverkris
« Reply #5 on: September 29, 2018, 08:20:46 AM »
Thank you both, that makes much more sense! I'm still at it, hope to get a few new ones done today!
Page created in 0.022 seconds with 28 queries.
