Author Topic: Unknown... ?Agate, perhaps?  (Read 6213 times)
Rosemaryr
« on: January 19, 2019, 01:25:41 PM »
I've been going through the stock of rough I have, that my dad left, and have pretty much got everything ID'ed.  Except for two slabs of the same material.  Green, swirly, partly translucent.  I tried the scratch test with a steel knife; it didn't seem to leave any indentation or scratch, although it did seem to leave a mark. Here are three pics: one dry, one wet, one with a backlight to show the translucency.
Any ideas?
Re: Unknown... ?Agate, perhaps?
« Reply #1 on: January 19, 2019, 02:05:22 PM »
My first thought was variscite, but that should have scratched.
VegasJames
« Reply #2 on: January 19, 2019, 06:16:39 PM »
I am thinking possibly a slag glass. Looks like bubbles in the upper left of the slab.
« Reply #3 on: January 20, 2019, 06:15:54 AM »
It looks like Polar jade.  How about streak.
« Reply #4 on: January 20, 2019, 07:32:28 AM »
Yeah, Polar/BC Jade looks right to me too.
Most of what little I know about jade is from this forum, so I was hoping one of you would ID it that way.
Heh, I even got confused by a slab of serpentine I posted a while back. It was really good serpentine... .
Rosemaryr
« Reply #5 on: January 20, 2019, 12:32:35 PM »
Bubbles were just the water I used to wet it with... no visible bubbles inside the slab itself.  ....and I thought that glass would have scratched with the steel.
Rosemaryr
« Reply #6 on: January 20, 2019, 12:37:27 PM »
Oooo, jade is a potential?  I haven't seen any jade images with that swirly look to them.
I do have another slab which *is* marked as jade from his collection, but that one looks nothing like these... that one is more of a standard, dark green nephrite style.  These two swirly slabs are both definitely different than that piece.
Rosemaryr
« Reply #7 on: January 20, 2019, 12:40:14 PM »
?  What would I use to test it with?  I don't have any real access to much in the way of testing equipment...  The steel knife tip I tried the scratch test with, did leave a  pencil-like mark, but that rubbed away with my fingertip, with no indication of any actual scratching of the slab material.
bobby1
« Reply #8 on: January 20, 2019, 01:11:31 PM »
Could you show a photo of the fracture surface on the bottom?
Bob
Rosemaryr
« Reply #9 on: January 20, 2019, 02:12:57 PM »
Bob
Here's the best end shot I could get... using my camera, which doesn't have a great level of zoom.  Also, a shot of the two unknowns next to the two slabs of jade from the collection.  We had a break in the weather, so these shots are in outdoor lighting, unlike the previous which were indoor with overhead and flash lighting.  I did reduce the image size... I didn't want to overload the forum's limits.  I can post a full image, if needed..but it would be about 2 Mgs (2592x1944 pixels).
« Reply #10 on: January 20, 2019, 05:01:38 PM »
This is just a WAG but it looks a lot like the hydrogrossular garnet rough I cut this cab from.  The hardness is right and so is the appearance.
Rosemaryr
« Reply #11 on: January 20, 2019, 08:50:14 PM »
That does look a lot like the stuff... especially compared to the second (wet) pic above.  I've seen some hydrogrossular garnet that is more spots and splotches, but your cab does have more of the swirled look.
« Reply #12 on: January 21, 2019, 06:52:35 AM »
You can get a streak test using any rough ceramic such as cheap dinner plates or white knife sharpener.  The back of a ceramic tile is what I have on my bench.
Michael
« Reply #13 on: January 21, 2019, 12:00:46 PM »
I purchased a nice piece of Polar (BC) jade at Quartzite QIA this week end.  These pictures look similar with what is called the "flame" component.  Good pictures.
Rosemaryr
« Reply #14 on: January 22, 2019, 09:01:17 AM »
Quote
It took me a while to find a suitable tile.  Tried it:  the unknown left no mark on the ceramic.  So, it could be either garnet or jade, according to the chart I found on-line.
Also tried a scratch test with a known piece of jade.  That was interesting.  The greener areas took no visible scratch, but the gray areas did.  The scratches were not perceptible to touch, but the marks would not rub away... they are indeed scratched into the surface.  So i am assuming that the grayer areas are not jade themselves, but some other material that looks gray when dry and green when wet.
Page created in 0.029 seconds with 46 queries.
