Author Topic: Recent Cabochon Vibe Tumble  (Read 2861 times)
victor1941
  • Retired art/science teacher
« on: June 27, 2019, 06:22:35 PM »
I preform my cabs on a 60-grit flat lap and finish all steps in a UV-18 vibe. This shows the finished product from some Priday Agate.
Re: Recent Cabochon Vibe Tumble
« Reply #1 on: June 27, 2019, 06:45:24 PM »
Nice looking cabs!  That third cab is freaking awesome!   :WEEEE:
« Reply #2 on: June 27, 2019, 09:10:00 PM »
A lot of good ones there.... I agree that third one is special!
« Reply #3 on: June 28, 2019, 11:26:52 AM »
Nice. What prepolish and polish do you use ?
victor1941
« Reply #4 on: June 29, 2019, 09:08:09 AM »
Lithicbeads, I use AlO 500 for 2 days, AlO 1000 for 2 days and add tripoli to mix for day 3, 3-5 days AlO polish(14,000) from The Rock Shed. All steps contain small media at least 50% of mix.
« Reply #5 on: June 30, 2019, 05:16:36 AM »
I’m curious. What is AIO polish and where do you get it? What sort of small media do you use? Do you mean small ceramic pellets? Crushed walnut? Something else?
victor1941
« Reply #6 on: June 30, 2019, 08:14:25 AM »
AlO is aluminum oxide and small ceramic media are non-abrasive 5/32" x 5/16" cylinders that I purchase from the Rock Shed. I told Shaun, the owner, what I wanted to do when I first started tumbling 5 years ago and this is what he suggested I do.
« Reply #7 on: June 30, 2019, 11:51:59 AM »
   Mixed media option:     Mixed media is small pieces that make sure all the areas of stones get polished, hitting all the nooks and crannies.  I use small pieces of the same material I am polishing. So if it is a batch of jasper I make sure and add a good amount of small pieces of jasper. There are plenty of spare tiny pieces from the trim saw and the pieces knocked off the edges of rough I work with. Since they are the same hardness they polish just right. I add them in from the first coarse polish and use them in each step.  As a bonus there is a small batch of tiny polished pebbles left at the end of each batch.
   Some softer materials are better off polished with soft media, nut shells, etc.
victor1941
« Reply #8 on: June 30, 2019, 07:50:18 PM »
55fossil, I also add the trimmings for the load of 8-9 pounds of cabs to be polished with the other 50%(9 pounds) being media. The UV-18 takes a lot of material to make the rotation correct which  also requires adding material after the initial rough grit phase. I only do cabs for the most part that are hard material but occasionally do use softer/less abrasive material on less hard stone. I do have some pom pom material from Needle Peak in Big Bend Park, Tx. that is fibrous and doesn't want to vibe without undercutting. Any help with this material would be appreciated.
Sapphireminer
« Reply #9 on: July 01, 2019, 03:53:23 AM »
You have some awesome cabs there just brilliant.  Dave
gjones
« Reply #10 on: July 03, 2019, 02:50:16 PM »
Beautiful Cabs, thanks for sharing!!
« Reply #11 on: July 04, 2019, 05:01:49 AM »
Thanks for the information!
Page created in 0.025 seconds with 40 queries.
