Author Topic: Star garnet  (Read 2179 times)
aksockeye
Star garnet
« on: August 13, 2019, 09:49:57 PM »
I have bought material from Idaho several times. I need advice from people that have experience. Tumbling seems to fracture the crystal. Maybe I let the tumbler dry and heat was the problem. I have cut some nice 4 star and I’m pretty sure I have a 6 star that I don’t want to try to finish until I know better.  Any help or advice is greatly appreciated.
Re: Star garnet
« Reply #1 on: August 13, 2019, 10:12:51 PM »
Not sure what the question is.  A little more info would be great.  Are you trying to find the proper way to tumble them, a better way to cut them or how to orient them etc..?
Re: Star garnet
« Reply #2 on: August 14, 2019, 12:49:24 PM »
I was taught by folks who cut many of these long ago. The center of the fractured garnet is where the asterism  that belongs on the top of the cab is found. They often abound with asterism but if you want a centered asterism  that is where you will find it. The old time cutters were not bahful and had lots of rough so they would put the fractured garnet in a cloth and tap it gently with a hammer and inspect it. The cloth keeps the pieces from  getting lost. They then cut the shards if large enough. You can make  bigger off center asterism cabs than perfectly centered ones as most rough is very small when you use the center of the shard as the top center of the cab. Realistically these garnets have never been tremendously functional except as small accent stones. Garnets are a lot harder than quartz  and the sanding and polishing is very different as  a properly prepared garnet will have a sand paper like finish well past the point that a quartz gem  is beginning to clean up.
Page created in 0.023 seconds with 25 queries.
