Author Topic: my 14" slab saw  (Read 3301 times)
William Phillips
my 14" slab saw
« on: September 05, 2019, 12:25:29 PM »
I have a Panther Lortone 14" slab saw. My problem is the rock I am cutting gets hot as does the oil, and saw blade. I have enough oil to cover about 3/8 inch of the blade. I have cut mostly Montana agate, picture jasper and jade. I have used a cutting stick to clean or sharpen the blade. Is my saw blade worn out?
Thanks
Re: my 14" slab saw
« Reply #1 on: September 05, 2019, 12:51:26 PM »
Those are tough rocks. I have a Lortone LS 12 and when it gets to where it is misting and heating I remove the blade and turn it around. This seems to get it cutting again.
Also when using a cutting stick, it is my experience that often multiple passes are required to sharpen a very dull blade.
As long as the sintered part of the blade is still there and wider than the core you should be able to get it cutting.
Re: my 14" slab saw
« Reply #2 on: September 05, 2019, 07:59:30 PM »
Is your oil clean or are you running mud? I too see heating and misting when the going gets tough but reversing the blade. running a few softer rocks through and adding a bit more oil may all help you plow through that tough rock.  The other option is to slow down your feed rate. Slow feed rates of 1 inch per 7 minutes are best but for problem blades etc. 10 minutes per inch would be better.
Re: my 14" slab saw
« Reply #3 on: September 05, 2019, 08:56:18 PM »
Jade will screw up many saws and blades.I would avoid jade if possible. My 24 struggles with jade with a new blade but deals with jasper quickly.Jade is not just hard it is tough, it is not cryptocrystalline or crystalline as are most lapidary roughs. The felted nature of the jade adds to the hardness. I use an ultrasonic drill and agates just get ground away by the bit , you can feel it giving way. Jade sort of absorbs much of the grinding shock and the headway is slow.Many jade cutters use drop saws as they are easier to get the force against the blade low enough to cut without dishing the blade.
William Phillips
Re: my 14" slab saw
« Reply #4 on: September 07, 2019, 04:10:41 PM »
Thanks for the information. I turned the saw blade around and cut the cutting stick several times. I then put a piece of petrified wood back in and made 3 slabs with no heat and no problem.  I did order a new blade from Minnesota Lapidary Supply so I am all set if I need to use the new one.
Page created in 0.014 seconds with 27 queries.
