Author Topic: Greenstone/jade/nephrite  (Read 4434 times)
Pito
« on: September 28, 2019, 06:22:37 PM »
Hey guys/gals my name is Karl. Pito is a business me and my partner are starting here in New Zealand the aspect of the business il be managing is greenstone carving otherwise known as jade/nephrite now I know bits and pieces but still haven't found a decent article on how to read nephrite grain would anyone be able to help me?
Thanks all the same 😊
Re: Greenstone/jade/nephrite
« Reply #1 on: September 28, 2019, 08:39:09 PM »
Welcome to the forum!
Here's an article that may help:  http://lapidaryforum.net/group/index.php?topic=4182.0
« Reply #2 on: September 29, 2019, 06:51:26 AM »
Welcome to the forum from western Oregon, USA
« Reply #3 on: September 29, 2019, 10:05:27 AM »
If you have a cobble that is water worn you are ahead of the game.You  need to identify the schistocity .Some jsdes are very uniform and the schistocity is of little importance but with others it is crucial to understand how bad the schistocity may become. The broad flat surfaces of a cobble are normally 90 degrees to the schistocity, that is if you are looking at the flat area of a cobble rotate it first to the side then to the narrowest point on the side. It is normally the narrowest because the schistocity is so well developed.Look for layering and look hard.If the piece is very schistose  you need to be showing the flat area of the cobble and minimize the thickness of the piece. Very aggressive wheels will develop the schistocity as will hitting the pieces with a hammer.Acut piece with no natural surfaces can be examined for schistocity as well.Some jade will show slight veiling when it comes off the saw as the saw will develop the schistocity in some jades. Using a 30 or 60 grit hard wheelon the corners of a piece will chip the spot if the shistocity is well developed. These brittle jades can be fine but you must be very careful and try to avoid harsh grinding. If all you have is your eyes wet the preform and rotate it looking for layers. All jaes have inclusions to a degree and they lie within the schistocity plane.If the slab - preform was cut incorrectly you will be plagued with the schistocity on the front surface of your piece. With very uniform jades this is no problem but most jades of reasonable cost are a risk.Because of the natural shape of a jade cobble it fits in the saw easily to cut it incorrectly.To cut along the face of the cobble which is preferable takes some planning and preliminary cuts.
Pito
« Reply #4 on: September 30, 2019, 02:08:15 AM »
Awesome thanks for the info guys definitely helps for my futher understanding being a new carver hopefully I can make some awesome items when I get fully set up that I can show you all 🤞
Windenzee
« Reply #5 on: October 01, 2019, 02:59:44 AM »
Not certain where in NZ you are based, but on the South Island in Hokitiki, there is a person that teaches/shows you how to carve Nephrite jade. May be worth checking him out.
Karen
Page created in 0.022 seconds with 31 queries.
