Author Topic: Cabbing advice  (Read 2769 times)
Mossagatemac
Cabbing advice
« on: January 02, 2020, 10:41:31 AM »
Hi Everyone,
I've been learning (self-teaching) how to cab on and off for the last 6 months and recently upgraded equipment to a cabking.  I'm still trying to get the hang of things and would appreciate some advice.  I don't have any local clubs that i can go to for in-person help, so posting some pictures here.
Like many new cabbers, i have trouble identifying scratches before they become problems near the higher grits.  When i noticed that problem, I've been marking the cab with a sharpie to make a "grid" and make sure i hit all the areas really well.
Below is a picture of my latest cab.  Probably my 5th attempt using the cabking.  Do the irregularities look like scratches or is the pitting just from the structure of the rock? Does that look normal to you?  Anything obvious i should try differently?
I took pictures at each grit stage to show what i'm working with.
First picture is finished cab from the top.
Second picture is after 600
Third picture is after 1200
Fourth picture is after 3000
Re: Cabbing advice
« Reply #1 on: January 02, 2020, 01:48:51 PM »
Looks great for such an early attempt...…   Just make sure and view the cab under good lights with magnification at each stage.
Rustycat
Re: Cabbing advice
« Reply #2 on: January 02, 2020, 03:16:46 PM »
Hi Everyone,
I found the following video on Youtube to be very interesting regarding rockhounding in Oregon/Idaho.  For those that have a specific interest in polishing, I recommend the last 15 minutes or so of the video showing how the use of hook and loop pads and automotive compounding are the products of choice for the final polishing of cabs.
https://www.youtube.com/watch?v=KrPel8lHPiA
Re: Cabbing advice
« Reply #3 on: January 02, 2020, 05:18:12 PM »
Usually any subsurface scratches will become apparent under 10-power magnification after 600 grit.  If any are detected that's the time to return to coarser grits until they're eliminated.  Dry your stone and check it thoroughly after each stage -- or do as I often do and discover the scratches after photographing the cab  :toothy10:
Shifter55
Re: Cabbing advice
« Reply #4 on: January 02, 2020, 06:50:19 PM »
Unfortunately those look like undercutting/pitting Mossagatemac, what has happened in the rock is the dark brown areas haven't taken up silica and are just soft iron concretion.
I've been having some similar troubles with some golden amphibolite recently and the texture is an exact match. Did you get a bit of brown runoff when you cut this material?
Outside of stabilising the exposed surface, I'm not really sure what to do...
Re: Cabbing advice
« Reply #5 on: January 03, 2020, 05:15:19 AM »
One thing not everyone does is look at the stone in strong light across the surface instead of directly at it.
Mossagatemac
Re: Cabbing advice
« Reply #6 on: January 03, 2020, 09:52:19 PM »
Shifter55 - yes, I could see the brown runoff when cutting and grinding.  I went back and used my old silicon carbide belts and polish on a leather pad to see if it would make any difference but I didn't see much change.
Re: Cabbing advice
« Reply #7 on: January 04, 2020, 06:40:07 AM »
I agree with all the undercutting/pitting and scratch detection tips previously mentioned.
If you have material with softer areas that undercut, about all you can do is use worn belts or laps and lighter pressure. Maybe slow down the movement of the cab against the belts, too. Just be sure to keep it moving. The little pits/vugs we all just have to live with.
Here's a link to a tool for examing your stones: https://www.sciplus.com/10x-triplet-loupe-47885-p
I like this style loupe so well I've bought one for both Robin and myself - and an extra one for the Jeep, so I always have one handy.
Mossagatemac
Re: Cabbing advice
« Reply #8 on: January 05, 2020, 07:14:27 PM »
Good advice about the loupe.  I wasn't sure how much of a difference it would make but I picked one up and tried it tonight.  Can really see where the scratches are and where to focus the sanding instead of guessing.  The worst part of using it is the cold drop of water that trickles up my arm when I raise the loupe to my eye. Gets me every time lol.
Picture of what I worked on tonight
Re: Cabbing advice
« Reply #9 on: January 05, 2020, 08:17:44 PM »
Here's another tip:  Keep a towel on your lap and use it to dry the stone and your hands before you raise that loop to your eye!   :laughing6:
Those cabs look great.  I think you've got it down.   :icon_sunny:
Re: Cabbing advice
« Reply #10 on: January 06, 2020, 05:06:13 AM »
Yeah, looks like whatever you're doing is working well.
Best advice I ever got - before I even started cutting - was "When you get done, if it's smooth and shiny then you did it right.".
Page created in 0.024 seconds with 41 queries.
