Author Topic: 12 mm ultrasonically drilled holes  (Read 3913 times)
« on: October 11, 2020, 07:27:30 PM »
I stopped just before break-through on the one hole to show you what we used to look for with the old diamond drilling on big holes  To prevent break-out, we would grind down to meet the rest of the hole, but the ultrasonic doesn't cause break-out.  I'm using a very large ball bit to  chamfer the holes.  Washington jade.
Re: 12 mm ultrasonically drilled holes
« Reply #1 on: October 11, 2020, 07:41:04 PM »
Interesting! Is this setup similar to that used in ultrasonic machining of cameos? Is there an abrasive slurry involved, or the tool comes with fixed abrasive?
« Reply #2 on: October 11, 2020, 08:58:51 PM »
Same tool.The cameos are carved in wax and cast in bronze then the bronze master is soldered to a horn instead of a bit.They form degrades as the bronze bit wears and the ones cut early in the run are considered more valuable. The ground forms are typically chased by a carver after tumbling to sharpen them up for the more expensive ones. It uses a sic slurry and hammers the grit into the stone.
« Reply #3 on: October 12, 2020, 09:48:59 AM »
Thanks for the article. Interesting to see different tools.
Page created in 0.029 seconds with 27 queries.
