Author Topic: Frantom 606 Trim Saw Bearing Replacement  (Read 3192 times)
Reclaimed NV
« on: November 22, 2020, 09:55:19 PM »
I am trying to replace the bearings on an old Frantom 606 trim saw. I have removed the arbor housing and believe I need to hammer (w/block of wood and copper hammer) the arbor to remove the first bearing. If this is correct am I first removing the inner or outer bearing? If not HOW do I remove the bearings?
Thank You in advance.
Joel
Reclaimed NV
Re: Frantom 606 Trim Saw Bearing Replacement
« Reply #1 on: November 23, 2020, 07:02:49 AM »
Photos would help.  Frantom made a fair number of models.  Procedure will depend on what you have.
Reclaimed NV
« Reply #2 on: November 23, 2020, 08:51:16 AM »
Model just says 606
Pics:
Update:  I removed the arbor and bearing housing. Copper hammer lightly striking the blade retaining nut. It will only come out one direction.  Now to get the bearings pressed out and replaced.
Page created in 0.023 seconds with 22 queries.
