Author Topic: Issues with drum advancing clutch mechanism in Hillquist slab saw.  (Read 3228 times)
Arturo_Osorio
Hello there!  :hello:
Hoping that your doing well, this is my first post...
I want to ask you a question. I have an old Hillquist slab saw and, recently, the drum advancing clutch mechanism photo1651527035.jpeg
*photo1651527035.jpeg (104.73 kB . 720x1280 - viewed 752 times) made the feed screw mechanism go slower every time (sometimes juest suddenly stops  :icon_scratch:). I did notice that the problem is on the clutch shoes, because when i gently press it, the drum rotates again.
Do you have similar experiences? How do you solve it?
I don't know what else to do.  :Bash:
Thanks  :hello2:
Re: Issues with drum advancing clutch mechanism in Hillquist slab saw.
« Reply #1 on: May 03, 2022, 04:29:39 AM »
Unless someone has that same saw, we will need more pictures and a more complete explanation of how you are making it work on a temporary basis.  Normally problems like this relate to loose set screws or worn threads on the feed rod. Do tell us more.
« Reply #2 on: May 03, 2022, 09:43:15 AM »
Welcome!  Our member Tony, camandewe should be able to help you. He is familiar with those saws. Good luck to you sir!
Page created in 0.024 seconds with 25 queries.
