Hello all
I'm rekindling my love of geology after a trip to the UP in Michigan. As a kid I would pick up rocks and fossils and then catalog them. I've kept quite a few over the year. I recently took a trip to Michigan's UP and picked up some agates as well as other rocks along Lake Superior. I purchased a rock tumbler and have my first dual 3 lb project running. I had one of the plastic drum units when I was a kid and didn't have the patience to let it go through completion, but now i'm exercising patience on this project. I found a local rock shop that sells bulk grit which saves quite a bit over the Thumblers grit packs, so i'm excited to see how my project turns out.
I also picked up two larger agates along Lake Superior and i'm interested about polishing them. Can I polish them using a dremel tool. I've hear of "windowing", i.e. just polishing a section off the agate and thought that a dremel might do the job. Any suggestions on steps and which attachment to a dremel I should use during each step would be helpful. Attached is a photo of my two larger agates (both found near Muskallonge Lake State park in Michigan's UP). One was between Grand Marais and Muskallonge Lake and the other was at the State Park.
