Author Topic: Foredom Bench Lathe died  (Read 2711 times)
WirednStonedbyKaren
« on: May 04, 2020, 05:44:09 AM »
Hi all!  New and happy to be here!  My problem: I have a Foredom Bench Lathe that I've had for years but have used less than 10 times.  I was screwing on a new buff wheel. I just tapped the power briefly to thread it and, out of the blue, it just stopped working.  The motor doesn't turnover at all - I don't even hear any power trying to get to it.  I checked the breakers - good there.  I plugged it in somewhere else and nothing.  It's like I need to reset it but no reset button (that I'm aware of).  I can't get through to anyone at Foredom.net.  Does anyone have an idea what's wrong or how to fix it?
Re: Foredom Bench Lathe died
« Reply #1 on: May 04, 2020, 08:38:58 AM »
It is almost certainly a broken connection.  Check all screw connections and if that doesn't work you are going to have to go to a continuity tester to find the break.
WirednStonedbyKaren
« Reply #2 on: May 04, 2020, 01:19:58 PM »
I assume you mean a broken connection within the bench lathe, right?
« Reply #3 on: May 04, 2020, 01:42:41 PM »
Yes.  Most likely in the switch.
« Reply #4 on: May 04, 2020, 03:34:05 PM »
Welcome to the forum!
Page created in 0.038 seconds with 29 queries.
